New RMVB CRT trans school me #1850937
06/17/15 07:35 AM
06/17/15 07:35 AM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
Hello, so new 544 stroker motor and CRT trans. John built for the motor with RMVB,car is ready to be out driving, abusing, can some folks school me on do's don'ts with this set-up? by that I'm meaning I have not driven a RMVB before, so shifting as a standard by rpm's, and downshifting when coming to a stop seems the way, what about burn-outs, start in 1st or 2nd from a stop? can you downshift to second when getting on highway or when cruising at 30 then punch it? appreciate the any schooling and do's and don'ts. and THANKS to a lot of the members here for helping me get to this point.
Re: New RMVB CRT trans school me [Re: meepmeep70] #1850942
06/17/15 08:18 AM
06/17/15 08:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Johns stuff is low band apply. Simply what ever gear you select at ANY time will engage. No need to do burnouts in low. Burnouts are about wheel speed. 2 to 3 or just start in 3
Doug
Re: New RMVB CRT trans school me [Re: meepmeep70] #1850944
06/17/15 08:37 AM
06/17/15 08:37 AM
weymouth,mass.
weymouth,mass.
thank you, so just punch in second or third, downshifting from third to second and punching would give the "rolling burn-out"? downshifting if normal driving and coming to a stop needed? or leave in 3 then shift to first when stopped? just trying to get how it works, for both driving hard and if just cruising.
scene 1- driving 30 mph coming to a red light, am I downshifting before I get to the stop, green 1st ect.?
scene 2- cruising and another car is trying to pass, shift into second punch it back to 3 leaving them in the dust?
sorry to ask such questions which are probably known to most in the race section, but it is less embarrassing on the computer then on the street smile
Re: New RMVB CRT trans school me [Re: meepmeep70] #1850960
06/17/15 10:06 AM
06/17/15 10:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah that VB should have LBA so it will decell with the engine..
think of it as driving a stick but without a clutch... any gear
your in is what your in... with that much engine you might not
use 1st much.... if your gonna street drive it.... I started my
burnouts in high gear.. you have to get on the throttle pretty good
but you can start in 2nd if you want also
EDIT
Remember that it wont up shift so you have to do it(same on
the down shift)
wave
Re: New RMVB CRT trans school me [Re: meepmeep70] #1850974
06/17/15 10:46 AM
06/17/15 10:46 AM
weymouth,mass.
weymouth,mass.
thank you smile
Re: New RMVB CRT trans school me [Re: meepmeep70] #1851094
06/17/15 02:57 PM
06/17/15 02:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
You may want to downshift into 2nd gear while rolling up to a stop and wait until stopped or almost stopped to shift it into 1 st gear to prevent putting teeth marks in the steering wheel whistling Depending on which rear gears your running work
Re: New RMVB CRT trans school me [Re: Cab_Burge] #1851164
06/17/15 04:25 PM
06/17/15 04:25 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
iagree
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: New RMVB CRT trans school me [Re: meepmeep70] #1851190
06/17/15 04:54 PM
06/17/15 04:54 PM
weymouth,mass.
weymouth,mass.
thank you, 3;55's at the moment, going to see how she runs then decide if I want more. appreciate all the help.
Re: New RMVB CRT trans school me [Re: DusterDave] #1851236
06/17/15 06:46 PM
06/17/15 06:46 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
iagree
iagreex,3
Re: New RMVB CRT trans school me [Re: meepmeep70] #1851241
06/17/15 06:56 PM
06/17/15 06:56 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
you could bang n to roll to a stop and put it in low to pull out
Re: New RMVB CRT trans school me [Re: dmking] #1851270
06/17/15 07:55 PM
06/17/15 07:55 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I hardly ever use first when I am street driving. I can smoke the tires starting off in third. You have alot more motor than I do. There is no reason to down shift until after you stop.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: New RMVB CRT trans school me [Re: dmking] #1851281
06/17/15 08:12 PM
06/17/15 08:12 PM
If you try to put in neutral from 3rd or 2nd gear it has to go through 1st, which engages it for a split second, hence the teeth marks in the steering wheel comment scope work shruggy Been there done that, I switched back to a non LBA valve body afer experiencing that at the races runaway My spare tranny had been freshen by one of the better race tranny company in SO CA and they had not warned me about them swapping out my T/A RMVB for a LBA RVMB tsk That was in my 1963 Plymouth M.W. stocker with the original pushbutton shifter, I would punch neutral after the finish line and it would grab 1st gear for a nanno second shock long enough to make me notice it was different than before, NOT GOOD tsk
Re: New RMVB CRT trans school me [Re: meepmeep70] #1852576
06/19/15 03:30 PM
06/19/15 03:30 PM
weymouth,mass.
weymouth,mass.
thank you all for the help.
