426 hemi sparkplug tubes #1850368
06/16/15 11:55 AM
06/16/15 11:55 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Built a 426 hemi. Installed drop tubes,0 rings for sparkplug tubes. Checking to see how plugs are burning and they come out with alot of great looking bradd penn oil on them. Is this the norm for the setup ?
Thanks in advance to all
Thanks MOPARTS
Re: 426 hemi sparkplug tubes [Re: terzmo] #1850393
06/16/15 12:28 PM
06/16/15 12:28 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
It's normal unless you have the spark plug tube oil damns.
see here for an example: http://www.manciniracing.com/mihehetuseki.html
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 426 hemi sparkplug tubes [Re: HemiRick] #1850400
06/16/15 12:41 PM
06/16/15 12:41 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Thanks.....good stuff....so remove plugs/covers and install ? Can be done with motor in ? Thanks again
Re: 426 hemi sparkplug tubes [Re: terzmo] #1850412
06/16/15 01:06 PM
06/16/15 01:06 PM
Cab_Burge Online work
Cab_Burge  Online Work
It can be done with the motor in the car or on a engene stand, put them in the freezer for a hour or two first and then installed them one at a time scope Make sure thier installed sqaure to the spark plug holes in the heads, I use small block of wood that is wider than the top of the aluminum seals to help drive and lightly tap them in square up IHTHs
Re: 426 hemi sparkplug tubes [Re: terzmo] #1850476
06/16/15 02:19 PM
06/16/15 02:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Did you install your sparkplugs with the compression washers on them?, if so you probably distorted the tube ends allowing oil into the cylinder via the plug threads and distorted plug tube base...the tube is your "plug washer", discard your plug washers if you haven't done so
Re: 426 hemi sparkplug tubes [Re: DAYCLONA] #1850515
06/16/15 03:08 PM
06/16/15 03:08 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
I understand...but.....it won't help the tubes now to remove the washers ??
Re: 426 hemi sparkplug tubes [Re: Cab_Burge] #1850523
06/16/15 03:13 PM
06/16/15 03:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I never trusted the metal-to-metal sealing of them, I always smear a light coat of RTV on them before installing.
