Re: 426 hemi sparkplug tubes
[Re: terzmo]
#1850412
06/16/15 01:06 PM
06/16/15 01:06 PM
Posts: 43,251 Bend,OR USA
Cab_Burge
Thanks.....good stuff....so remove plugs/covers and install ? Can be done with motor in ? Thanks again It can be done with the motor in the car or on a engene stand, put them in the freezer for a hour or two first and then installed them one at a time Make sure thier installed sqaure to the spark plug holes in the heads, I use small block of wood that is wider than the top of the aluminum seals to help drive and lightly tap them in square IHTHs
[Re: DAYCLONA]
#1850515
06/16/15 03:08 PM
06/16/15 03:08 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
Did you install your sparkplugs with the compression washers on them?, if so you probably distorted the tube ends allowing oil into the cylinder via the plug threads and distorted plug tube base...the tube is your "plug washer", discard your plug washers if you haven't done so I understand...but.....it won't help the tubes now to remove the washers ??
[Re: Cab_Burge]
#1850523
06/16/15 03:13 PM
06/16/15 03:13 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It can be done with the motor in the car or on a engene stand, put them in the freezer for a hour or two first and then installed them one at a time Make sure thier installed sqaure to the spark plug holes in the heads, I never trusted the metal-to-metal sealing of them, I always smear a light coat of RTV on them before installing.
