Blow Thru Carbs #1850026
06/15/15 10:24 PM
06/15/15 10:24 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
I notice that most of the blow thru carbs on ebag are in the 650 to 850 range. Not many 950 or 1050 carbs advertised. When buying mine should I buy the size I'm using on my N/A engine or is it appropriate to go slightly swmaller or slightly larger. I'm currently using a 950 on a 413 smallblock. Thanks, Max
Re: Blow Thru Carbs [Re: Blucuda413] #1850030
06/15/15 10:32 PM
06/15/15 10:32 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Call kevin at CSU carbs. He will set you up with what you need for your combo
Re: Blow Thru Carbs [Re: Blucuda413] #1850035
06/15/15 10:36 PM
06/15/15 10:36 PM
Az
Crizila Offline
Crizila  Offline
Az
I actually had my holley 900 on my NA motor converted when I went to a blow through motor. GIANT annular boosters were installed, so I am sure it doesn't flow 900 cfm ( if it ever did ) any more. According to what I have heard, you can go to a smaller cfm carb in a blow through application, but I saved myself about $400 having mine converted. I will say I have some rich / lean issues that I am still trying to sort out, but not equating it to carb size right now.
Fastest 300
Re: Blow Thru Carbs [Re: Blucuda413] #1850044
06/15/15 10:47 PM
06/15/15 10:47 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I ran a 950 on my 416 small block, that is what Steve Morris recommended.
Re: Blow Thru Carbs [Re: Blucuda413] #1854196
06/22/15 09:42 AM
06/22/15 09:42 AM
Maryland, USA
Raymond Offline
Raymond  Offline
Maryland, USA
you can run a smaller car.I run low 8s on my 394 w5 s.b with a
csu 850
Re: Blow Thru Carbs [Re: Blucuda413] #1854998
06/23/15 08:04 AM
06/23/15 08:04 AM
ma.
duspan Offline
duspan  Offline
ma.
hello
i see that you run two carb spacers are they both open or is the top one a tapered four hole?
thanks
duspan
