Convertible Roof Issues #1844361
06/08/15 06:14 PM
06/08/15 06:14 PM
Germany
1964Polara Offline OP
Germany
1968 Fury Convertible the electrical roof gets tired and open/closes just with
manual help. Where should I look first? Hydraulic cylinders?
Re: Convertible Roof Issues [Re: 1964Polara] #1844392
06/08/15 06:59 PM
06/08/15 06:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Make sure the fluid is full and bled the system. If that doesn't help then it's more likely the pump then the cylinders. The cylinders are only as good as the pressure they get.
Re: Convertible Roof Issues [Re: 1964Polara] #1844669
06/09/15 12:09 AM
06/09/15 12:09 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
got full voltage to it?
Re: Convertible Roof Issues [Re: 1964Polara] #1845371
06/09/15 10:37 PM
06/09/15 10:37 PM
Back in Blue Jersey.
P
polara71 Online content
polara71  Online Content
P
I agree with checking the system for air in the lines and making sure shes full. Of course pumps go bad but its been my experience the cylinders go first. If your system is low on fluid, it is usually because there is a reason.......= Cylinder leak
Re: Convertible Roof Issues [Re: 1964Polara] #1849760
06/15/15 05:54 PM
06/15/15 05:54 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
When my Challenger got tired I pulled the rear seat. Lines had slowly leaked. Replaced, refilled, bled. Good as new.
Re: Convertible Roof Issues [Re: 1964Polara] #1872179
07/17/15 07:01 AM
07/17/15 07:01 AM
Germany
Germany
Thanx for the input! Will check soon once I got time (;-)
