E body shifter linkage
#1846981
06/11/15 10:49 PM
06/11/15 10:49 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
Im in the middle of installing the shifter linkage on the 4 speed in my cuda. The 1-2 and 3-4 operating levers on the side of the transmission have a top and bottom hole that the rod goes through. The rods go in the top hole correct?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: E body shifter linkage problems
[Re: sgcuda]
#1847327
06/12/15 01:20 PM
06/12/15 01:20 PM
73cuda340
clarks summit pa
Ok thanks. The reason Im asking is because I have them installed in the top holes and when I went to adjust my linkage on the 3-4 rod, the swivel is maxed out, but it still has to thread in more to fit into the lever on the shifter.
[Re: 73cuda340]
#1847973
06/13/15 11:21 AM
06/13/15 11:21 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Make sure the tabs are installed correctly. They should point straight upwards when in neutral. Put a drill bit through the shifter to hold all of the linkage in the neutral position before adjusting.
[image][/image]
[Re: sgcuda]
#1848175
06/13/15 04:59 PM
06/13/15 04:59 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Make sure the tabs are installed correctly. They should point straight upwards when in neutral. Put a drill bit through the shifter to hold all of the linkage in the neutral position before adjusting. Also check to see if your shifter box has shifter stops, they will need to be readjusted also
