E body shifter linkage #1846981
06/11/15 10:49 PM
06/11/15 10:49 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Im in the middle of installing the shifter linkage on the 4 speed in my cuda. The 1-2 and 3-4 operating levers on the side of the transmission have a top and bottom hole that the rod goes through. The rods go in the top hole correct?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: E body shifter linkage [Re: 73cuda340] #1847320
06/12/15 01:10 PM
06/12/15 01:10 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
They can go in either. The hole closer to the pivot will give you a shorter shifter throw.
[image][/image]
Re: E body shifter linkage problems [Re: sgcuda] #1847327
06/12/15 01:20 PM
06/12/15 01:20 PM
clarks summit pa
clarks summit pa
Ok thanks. The reason Im asking is because I have them installed in the top holes and when I went to adjust my linkage on the 3-4 rod, the swivel is maxed out, but it still has to thread in more to fit into the lever on the shifter.
Re: E body shifter linkage problems [Re: 73cuda340] #1847973
06/13/15 11:21 AM
06/13/15 11:21 AM
sgcuda Offline
sgcuda  Offline
Make sure the tabs are installed correctly. They should point straight upwards when in neutral. Put a drill bit through the shifter to hold all of the linkage in the neutral position before adjusting.
[image][/image]
Re: E body shifter linkage problems [Re: sgcuda] #1848175
06/13/15 04:59 PM
06/13/15 04:59 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Also check to see if your shifter box has shifter stops, they will need to be readjusted also
Re: E body shifter linkage problems [Re: 73cuda340] #1848199
06/13/15 05:54 PM
06/13/15 05:54 PM
The stock long snaky looking E body shifter rods will bend making them end up shorter, which will max out the swivels. Use the bottom hole now and readjusted the positive stops with the tranny in each gear, adjust so the bolt barely touches the shifter lever on the shifter and lock the nut down tight up twocents Once they get unusable from power shifting devil you will need to either straighten them back to original and reinforce them or replace them, if you can find those rods now scopeIHTHs up
Re: E body shifter linkage problems [Re: Cab_Burge] #1848588
06/14/15 11:29 AM
06/14/15 11:29 AM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
They should look like this.I have rods if you need them.
