E body ac issues #1845444
06/09/15 11:53 PM
06/09/15 11:53 PM
S.florida
Jupiter331 Offline OP
S.florida
Factory ac system. Low pressure line freezing. Refrigerant is at proper level???? Also is there any easy way to increase the ac / heat fan speed??
Re: E body ac issues [Re: Jupiter331] #1845501
06/10/15 01:07 AM
06/10/15 01:07 AM
BDW Offline
BDW  Offline
Too many voltage drops to fan, I added a relay to supply battery voltage directly to fan motor.
Downside is I only have high speed now, but living in FL it's what I needed.
Duct work on these cars is terrible too, might need to get under the dash and start taping up the joints.
Re: E body ac issues [Re: Jupiter331] #1845617
06/10/15 10:43 AM
06/10/15 10:43 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Has the blower motor been replaced? My experience is that the secondary market blowers do not work nearly as well as the OEM blower. I hope there is one out there that does work but I have not found it yet after three tries. For me, A/C and Defrost do not have the output needed to do the job. Using a relay is about the only alternative since max output with the newer motors is the equivalent of medium on the OEM blower.
Craig
Re: E body ac issues [Re: Jupiter331] #1845619
06/10/15 10:53 AM
06/10/15 10:53 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Craig
Not cheap but if you still have the old one you could send it out for exchange for one that has been restored.
http://www.bmcuda.com/products.asp?cat=10
Re: E body ac issues [Re: denfireguy] #1845655
06/10/15 11:57 AM
06/10/15 11:57 AM
S.florida
S.florida
What type of relay do l need? How did you wire it up???
Re: E body ac issues [Re: Jupiter331] #1847060
06/12/15 12:05 AM
06/12/15 12:05 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
A simple Bosche style is the easiest to find.
http://www.ebay.com/itm/Car-Truck-Auto-A...c54&vxp=mtr
One similar to this. Found in just about any auto parts store with a socket as well.
Craig
Re: E body ac issues [Re: Jupiter331] #1847548
06/12/15 06:35 PM
06/12/15 06:35 PM
CJD AUTOMOTIVE Offline
If the low side is freezing, it's probably a restriction or TXV. Need to know what your pressures are. With the gauges does the low side pressure try to pull down to zero or even a vacuum before cycling?
For the fan, try and adapt a late model Caravan dual blade fan. Those move a monstrous amount of air. Spinning the old fan faster is going to have limited results. And get a OE fan! The aftermarkets have really bad blade designs and don't move much air but make lots of noise!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
