E body ac issues
#1845444
06/09/15 11:53 PM
06/09/15 11:53 PM
Posts: 71 S.florida
Jupiter331
S.florida
Factory ac system. Low pressure line freezing. Refrigerant is at proper level???? Also is there any easy way to increase the ac / heat fan speed??
Re: E body ac issues
[Re: Jupiter331]
#1845617
06/10/15 10:43 AM
06/10/15 10:43 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Has the blower motor been replaced? My experience is that the secondary market blowers do not work nearly as well as the OEM blower. I hope there is one out there that does work but I have not found it yet after three tries. For me, A/C and Defrost do not have the output needed to do the job. Using a relay is about the only alternative since max output with the newer motors is the equivalent of medium on the OEM blower. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Jupiter331]
#1845619
06/10/15 10:53 AM
06/10/15 10:53 AM
Posts: 13,596 md
mopars4ever
md
Has the blower motor been replaced? My experience is that the secondary market blowers do not work nearly as well as the OEM blower. I hope there is one out there that does work but I have not found it yet after three tries. For me, A/C and Defrost do not have the output needed to do the job. Using a relay is about the only alternative since max output with the newer motors is the equivalent of medium on the OEM blower. Craig Not cheap but if you still have the old one you could send it out for exchange for one that has been restored. http://www.bmcuda.com/products.asp?cat=10
[Re: Jupiter331]
#1847060
06/12/15 12:05 AM
06/12/15 12:05 AM
denfireguy
Colorado
A simple Bosche style is the easiest to find. http://www.ebay.com/itm/Car-Truck-Auto-A...c54&vxp=mtrOne similar to this. Found in just about any auto parts store with a socket as well. Craig
[Re: Jupiter331]
#1847548
06/12/15 06:35 PM
06/12/15 06:35 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Factory ac system. Low pressure line freezing. Refrigerant is at proper level???? Also is there any easy way to increase the ac / heat fan speed?? If the low side is freezing, it's probably a restriction or TXV. Need to know what your pressures are. With the gauges does the low side pressure try to pull down to zero or even a vacuum before cycling? For the fan, try and adapt a late model Caravan dual blade fan. Those move a monstrous amount of air. Spinning the old fan faster is going to have limited results. And get a OE fan! The aftermarkets have really bad blade designs and don't move much air but make lots of noise!
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
