69 440 A body Exh. Manifold spacer ? #1847057
06/12/15 12:02 AM
06/12/15 12:02 AM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Looking for info on the spacer between the exhaust manifold and the engine pipe. Would anyone have a picture or part # and know if they are currently being reproduced ? .
Re: 69 A12 Exh. Manifold spacer ? [Re: 493RT] #1847101
06/12/15 12:43 AM
06/12/15 12:43 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Are you talking about the flange gaskets between the exhaust manifold and the headpipe ?
Dont know if they are in repro, I would assume so.
If not I have some long discontinued NOS ones.
PM me if you are interested.
Re: 69 A12 Exh. Manifold spacer ? [Re: mccannix] #1847112
06/12/15 01:03 AM
06/12/15 01:03 AM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Sorry mccannix it is actually for a 69 A body on the right hanh side.
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #1847193
06/12/15 08:25 AM
06/12/15 08:25 AM
Woodbridge
Tommy The Chryco Offline
Woodbridge
yes they are being reproduced everyone should have them
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #1847250
06/12/15 10:55 AM
06/12/15 10:55 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
This may be what your looking for reproduced my Accurate exhaust. The kit is $55.00.
http://www.accurateltd.com/Flanges-including-LP-HP-Floating-and-Spacer-Kits_c_10.html
Matt
Re: 69 440 A body Exh. Manifold spacer ? [Re: mattsmopars] #1847730
06/12/15 10:40 PM
06/12/15 10:40 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
That would be it , thanks
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #1850935
06/17/15 07:22 AM
06/17/15 07:22 AM
USA
big-block-dave Offline
USA
I believe Accurate got ahold of a picture of one of mine. I know for a fact that a guy bought one and it was nothing more than 2 flanges welded together crap. Nothing like there picture.
If you buy one post some pics please, Dave
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: 69 440 A body Exh. Manifold spacer ? [Re: big-block-dave] #1850998
06/17/15 11:52 AM
06/17/15 11:52 AM
Northern BC
Canucklehead Offline
Northern BC
That's how mine came, two flanges welded together. The hardware was garbage, too. Be careful with that one.
Re: 69 440 A body Exh. Manifold spacer ? [Re: Canucklehead] #1851027
06/17/15 12:45 PM
06/17/15 12:45 PM
Mass
charge70 Offline
charge70  Offline
Mass
An original spacer is cast iron and is 3/4" thick.I don't have a pic of mine,but that's what I remember when I mine had it off the car.John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 69 440 A body Exh. Manifold spacer ? [Re: charge70] #1852114
06/18/15 09:31 PM
06/18/15 09:31 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
We have been reproducing these 440 spacer kits for about 15 years and we did not copy the design from the person claiming we did so on this thread. This is the spacer kit that we have been using with our "M" code exhaust systems successfully without any issues. For those requiring a cast iron appearance spacer kit these are also available. There are better ways to promote a persons product without using derogatory statements regarding that of others.
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #1852194
06/18/15 10:55 PM
06/18/15 10:55 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Our own big_block_dave makes them also, I bought one from him years ago. Also, the products Tom Swope makes are second to none. up
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 440 A body Exh. Manifold spacer ? [Re: Tom Swope] #1852438
06/19/15 11:35 AM
06/19/15 11:35 AM
blewbyu Offline
blewbyu  Offline
Tom, did you ever make the one that was 2 flanges welded together? If so this might clear up the comments above. Now with your post these people will know that you did make a change at some time. Just my 2 cents
Re: 69 440 A body Exh. Manifold spacer ? [Re: Rhinodart] #1852456
06/19/15 12:11 PM
06/19/15 12:11 PM
Northern BC
Northern BC
I bought mine 3 years ago and maybe they have changed the design since then, but mine had a very obvious seam where the 2 flanges met. It was not welded on the outside of the flange and finished, it was just a seam running horizontally across the flange. Also, the hardware was stuff I could have grabbed out our bolt bin at work, except for the bolt retainers. "Garbage" was a strong word, apologies to Tom. I do not believe that the "cast finish" was an option when I bought mine.
Re: 69 440 A body Exh. Manifold spacer ? [Re: blewbyu] #1852467
06/19/15 12:40 PM
06/19/15 12:40 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
Our design is the two lazer cut flanges that are welded together.
The available cast appearing external coating makes the part appear to be pretty close to the original rare piece. The numbers matching user probably would require an nos cast part but this kit was designed to be an economical option to fill a need not for the points correct application.
We have had good success over the years with these kits with no complaints other than a few on this board so we will continue with this design for our specific market. We are appreciative of those on this board that have supported us in the past with both their business and comments. Being a manufacturer of over 500 Mopar exhaust parts any input regarding our product(s) is very much appreciated.
Re: 69 440 A body Exh. Manifold spacer ? [Re: big-block-dave] #1852541
06/19/15 02:45 PM
06/19/15 02:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Dave, hope you still have some. If so I'll use your spacer and Toms exhaust. I need it as close to original as I can get. Mike
Re: 69 440 A body Exh. Manifold spacer ? [Re: cudaman1969] #1852930
06/20/15 12:04 AM
06/20/15 12:04 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Big Block Dave is the man. This is mine from Dave with my finishing touches
IF YOU ARE GOING TO MAKE THEM! MAKE THEM RIGHT!!!!
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #1852946
06/20/15 12:22 AM
06/20/15 12:22 AM
blewbyu Offline
blewbyu  Offline
I got mine from Big Block Dave and it is spot on. I would really like to see a picture of the one you sell and that would clear all the misunderstanding up. The one in the picture does not appear to be 2 pieces welded together.
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #1858615
06/28/15 12:15 AM
06/28/15 12:15 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
no picture of the other one. must not be that nice
mcodecuda@yahoo.com
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #1863756
07/04/15 06:52 PM
07/04/15 06:52 PM
Kentucky USA
RR6BBL1969 Offline
RR6BBL1969  Offline
Kentucky USA
So, who has the "correct" cast iron spacer that you guys like?
Re: 69 440 A body Exh. Manifold spacer ? [Re: blewbyu] #1864421
07/05/15 06:08 PM
07/05/15 06:08 PM
Kentucky USA
RR6BBL1969 Offline
RR6BBL1969  Offline
Kentucky USA
What is the web address or phone number of big-block-Dave so I can order one of his A body 440 exhaust spacers? Sounds like his is the best from everyone's posts. Thanks
G.G.
