Anybody using Firm Feel stage 3 steering gear box? #184682
01/05/09 04:25 PM
01/05/09 04:25 PM
South San Francisco, Ca
70sixpkrt Offline OP
I just pulled my power steering gear box out because it was leaking. Thinking about going with a Firm Feel Stage 3 box. Anybody using one? How do you like it? Should I go with the larger sector shaft?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 70sixpkrt] #184683
01/05/09 04:43 PM
01/05/09 04:43 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've installed a few & have always highly recomended the level 3, but I did recently have someone that felt it was to heavy & removed the level three sent it back & exchanged it for a level 1... FWIW I still prefer the level 3, if you want a Cadillac buy a Cadillic
As far as the large sector, the pitman arm is much easier to find & much cheaper so yes I would use the large sector shaft...Unless you have a new small shaft pitman arm in your stash...
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 1_WILD_RT] #184684
01/05/09 04:48 PM
01/05/09 04:48 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i have my TA ps box rebuilt to a stage 3 and i like it
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: aarcuda] #184685
01/05/09 05:06 PM
01/05/09 05:06 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
i have a 3 and like it
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: VanishPt] #184686
01/05/09 05:53 PM
01/05/09 05:53 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Go with the FF 3 you won't regret it. I had a S&G level 2 before and thought it was too loose. The FF3 is nice and firm but not hard to turn.
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 500Stroker] #184687
01/05/09 07:05 PM
01/05/09 07:05 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I have a stage 3 box with their fast ratio arms. One of the best things I have done to the car.
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: RTSE4ME] #184688
01/05/09 08:33 PM
01/05/09 08:33 PM
It looks like I will be ordering their stage 3 with the larger shaft tommorrow. I can't afford their fast ratio pitman arm but that's ok. I can get a Moog pitman arm for $80. Thanks for all the replies.!!
4-speed
3:54 Dana
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 70sixpkrt] #184689
01/05/09 11:29 PM
01/05/09 11:29 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
It looks like I will be ordering their stage 3 with the larger shaft tommorrow. I can't afford their fast ratio pitman arm but that's ok. I can get a Moog pitman arm for $50. Thanks for all the replies.!!
With that large sector box doesnt the pitman arm they recommend not work with some brands of headers? I will be ordering a box from them soon but I dont think I will get a large sector because I have Hooker ceramic coat 1 7/8 COMP Headers.....can anybody confirm this? I have a 70 Charger RT with 4speed also.
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: Blakcharger440] #184690
01/05/09 11:39 PM
01/05/09 11:39 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i know on an ebody, TTI says you cant use their headers ith the fast ratio arm at least on a small block.
I am running hooker super comps 5115 on my cuda with the fast ratio box just fine
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: Blakcharger440] #184691
01/05/09 11:58 PM
01/05/09 11:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The "quick ratio" pitman arm which is avaliable in large shaft & small shaft is what causes the interference..There is a standard pitman arm in the large spline as well...
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: Blakcharger440] #184692
01/06/09 12:02 AM
01/06/09 12:02 AM
Shoreline, Washington
72roadrunnergtx Offline
I recently purchased a rebuilt stage 2 large sector shaft box (73’ and up P/S Mopar gear box) from Firm Feel for a 72’ GTX. The standard ratio large sector pitman arm (73’ and up application) will not cause header clearance problems. The fast ratio pitman (small or large sector shaft) is longer than the standard arm, moving the position of the center link aft and in possible conflict with some headers.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 72roadrunnergtx] #184693
01/06/09 12:13 AM
01/06/09 12:13 AM
When I talked to Firm Feel today, they said they also sell a standard large pitman arm. The quick ratio arm is the one that interferes.
4-speed
3:54 Dana
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 70sixpkrt] #184694
01/06/09 12:14 AM
01/06/09 12:14 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You can get the standard large spline pitman at Napa...
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 1_WILD_RT] #184695
01/06/09 12:14 AM
01/06/09 12:14 AM
Wichita,KS
Wichita,KS
Well thats good news! Now I can order up my box with no worries! Thanks!
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 1_WILD_RT] #184696
01/06/09 12:22 AM
01/06/09 12:22 AM
"You can get the standard large spline pitman at Napa..."
yes, tell'm it's for a 73'.
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 72roadrunnergtx] #184697
01/06/09 12:25 AM
01/06/09 12:25 AM
Napa shows 2 different pitman arms for a 73 Charger. One for $43 and the other for $76. Why?
4-speed
3:54 Dana
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 70sixpkrt] #184698
01/06/09 12:27 AM
01/06/09 12:27 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Manual steering??
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 1_WILD_RT] #184699
01/06/09 12:29 AM
01/06/09 12:29 AM
4-speed
3:54 Dana
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 70sixpkrt] #184700
01/06/09 12:36 AM
01/06/09 12:36 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Take a look at the photos, one looks correct & one doesn't...
Re: Anybody using Firm Feel stage 3 steering gear box? [Re: 1_WILD_RT] #184701
01/06/09 12:36 AM
01/06/09 12:36 AM
So, which one is correct?
4-speed
3:54 Dana
