cooling fan to water pump bolts #1846896
06/11/15 09:25 PM
06/11/15 09:25 PM
Louisiana
duckblind Offline OP
Louisiana
Does anyone know the size bolt/length to connect the cooling fan to the water pump on a 68 440?
Re: cooling fan to water pump bolts [Re: duckblind] #1847124
06/12/15 01:23 AM
06/12/15 01:23 AM
not sure of the OE dia/length but I'd measure the length needed to reach near the end of the rear side of the WP "cross". you have the fan the pulley the spacers (if used) & the cross & probably washers, Mancini or 440 source etc might have kits of those 4 bolts (would hurt to double check the length needed for your app). EDIT grade 5 is plenty
