1982 Dodge truck water getting gas tank how???? #1844303
06/08/15 04:18 PM
06/08/15 04:18 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
My 1982 Dodge truck has water getting into the gas tank how???? Anyone have any ideas? I did drop the tank a few years ago and drilled holes in to the bed to get to the tank mounting bolts. This problem just started in the past 6 months. I mean lotsa water the gas I'm pumping out of it is coming out 25/75 gas water.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 1982 Dodge truck water getting gas tank how???? [Re: HemiRick] #1844312
06/08/15 04:31 PM
06/08/15 04:31 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The only way to insure clean dry gas is to keep the tank totally full of gas when stored. I can't emphasize that enough.
You will never know for sure how much water is in there unless you can stick the tank for water with water paste.
I'm in the fuel business and use this stuff all the time.
Lastly methanol is idea for rinsing out the tank after it has had water in it. It's one of the few things that will totally get all the water out so your tank won't rust. You would have to remove tank again to use methanol since you have to dump all the methanol out by turning the tank upside down after rinsing. But it will totally dry out your tank.
Re: 1982 Dodge truck water getting gas tank how???? [Re: Challenger 1] #1844315
06/08/15 04:38 PM
06/08/15 04:38 PM
Cincinnati, Ohio
Cincinnati, Ohio
Maybe the tank filler tube grommet is not sealing and rain water is running down the filler tube into the fuel tank??
Re: 1982 Dodge truck water getting gas tank how???? [Re: HemiRick] #1844399
06/08/15 07:09 PM
06/08/15 07:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Maybe the station you are buying your gas from has water in their tank. 25/75 is an awful lot of water to be condensation .
Re: 1982 Dodge truck water getting gas tank how???? [Re: Challenger 1] #1845181
06/09/15 07:43 PM
06/09/15 07:43 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 1982 Dodge truck water getting gas tank how???? [Re: HemiRick] #1845272
06/09/15 09:18 PM
06/09/15 09:18 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
The poly tanks will split on top when they get old. Also, there should be an o-ring under the sending unit. Might be dry-rotted.
Re: 1982 Dodge truck water getting gas tank how???? [Re: HemiRick] #1845403
06/09/15 11:10 PM
06/09/15 11:10 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
I posted a reply once all ready but I dont see it so I'll try again.
I think water was getting on top of the tank from the rearmost hole I drilled to access the bolts. I've sealed up this hole. We'll see if it cures the problem.
Take care,
Rick
Re: 1982 Dodge truck water getting gas tank how???? [Re: HemiRick] #1845451
06/10/15 12:03 AM
06/10/15 12:03 AM
N
NITROUSN Offline
NITROUSN  Offline
N
That's just a poor band aid to the problem. Something is rotted or cracked. Sending unit sits in a pod area. Dodge packed the cavity with grease when new to prevent rusting through. If its been worked on and the grease was removed. My bets its rusted through. So rain, washing, and just about anything else will get in there.
Re: 1982 Dodge truck water getting gas tank how???? [Re: HemiRick] #1845552
06/10/15 03:07 AM
06/10/15 03:07 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I had my '92 w250's tank getting water in it...finally found out that the metal upper filler tube had rubbed thru were the bend was at the inner box panel...about a foot down from the filler.
