1982 Dodge truck water getting gas tank how????
#1844303
06/08/15 04:18 PM
06/08/15 04:18 PM
Posts: 4,848 Memphis
HemiRick
Memphis
My 1982 Dodge truck has water getting into the gas tank how???? Anyone have any ideas? I did drop the tank a few years ago and drilled holes in to the bed to get to the tank mounting bolts. This problem just started in the past 6 months. I mean lotsa water the gas I'm pumping out of it is coming out 25/75 gas water.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 1982 Dodge truck water getting gas tank how????
[Re: HemiRick]
#1844312
06/08/15 04:31 PM
06/08/15 04:31 PM
Challenger 1
Cincinnati, Ohio
My 1982 Dodge truck has water getting into the gas tank how???? Anyone have any ideas? I did drop the tank a few years ago and drilled holes in to the bed to get to the tank mounting bolts. This problem just started in the past 6 months. I mean lotsa water the gas I'm pumping out of it is coming out 25/75 gas water. The only way to insure clean dry gas is to keep the tank totally full of gas when stored. I can't emphasize that enough. You will never know for sure how much water is in there unless you can stick the tank for water with water paste. I'm in the fuel business and use this stuff all the time. Lastly methanol is idea for rinsing out the tank after it has had water in it. It's one of the few things that will totally get all the water out so your tank won't rust. You would have to remove tank again to use methanol since you have to dump all the methanol out by turning the tank upside down after rinsing. But it will totally dry out your tank.
[Re: Challenger 1]
#1845181
06/09/15 07:43 PM
06/09/15 07:43 PM
Posts: 2,111 Byron, NY
W.I.N. Racing
Byron, NY
Maybe the tank filler tube grommet is not sealing and rain water is running down the filler tube into the fuel tank??
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: HemiRick]
#1845403
06/09/15 11:10 PM
06/09/15 11:10 PM
HemiRick
Memphis
I posted a reply once all ready but I dont see it so I'll try again.
I think water was getting on top of the tank from the rearmost hole I drilled to access the bolts. I've sealed up this hole. We'll see if it cures the problem.
[Re: HemiRick]
#1845451
06/10/15 12:03 AM
06/10/15 12:03 AM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I think water was getting on top of the tank from the rearmost hole I drilled to access the bolts. I've sealed up this hole. We'll see if it cures the problem. That's just a poor band aid to the problem. Something is rotted or cracked. Sending unit sits in a pod area. Dodge packed the cavity with grease when new to prevent rusting through. If its been worked on and the grease was removed. My bets its rusted through. So rain, washing, and just about anything else will get in there.
