Machine shop near Eugene Or. #1845491
06/10/15 12:53 AM
06/10/15 12:53 AM
W
Wagonman1967 Offline OP
W
I had my 383 cleaned and maged and measured.Local guy wants to bore and deck it. I am OK with that but asked him if they use torque plates. Advised Me they are not needed.So I will pick up my block and look for someone who dose. Any recomendations ???
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: Machine shop near Eugene Or. [Re: Wagonman1967] #1845754
06/10/15 02:29 PM
06/10/15 02:29 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
Call Laroy engines in challis id. Mopar only shop!
Re: Machine shop near Eugene Or. [Re: Wagonman1967] #1845759
06/10/15 02:37 PM
06/10/15 02:37 PM
Call Southward 541-431-0556 and make sure you use the same head gaskets and fasteners lengths on the torque plates as your going to use on your motor, they may not have the .022 thick small bore steel shims head gaskets for the 383 and 426W 4.250 bore size scope If they don't I do, they stop here regulary so I can loan them to them when they stop in here the next time up
Re: Machine shop near Eugene Or. [Re: Wagonman1967] #1845779
06/10/15 03:04 PM
06/10/15 03:04 PM
AndyF Offline
AndyF  Offline
I'm not familiar with any shops in the Eugene area but Gray's Automotive in McMinnville is very experienced with Mopar engines. Gray's has torque plates as well as a number of other Mopar specific tools. Gray's is also set up with headers and motor mounts to dyno test SB and BB Mopar engines.
