hooking a new Challenger #1843556
06/07/15 05:49 PM
06/07/15 05:49 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I'm trying to gain some sixty foot and consistency in my SRT. It's stock suspension with BFG street tires. I drive around the water, back up about two feet from the water, then do a hard dry hop to clean the tires and build a little heat. Then stage, and have to lightly roll into the throttle until it hooks in 2nd gear, then I can finally go WFO.
Anyone have any luck getting these things to launch.
I have some mid 7's in the 1/8 if I can find some hook. Went 7.92 rolling into the throttle.
I'd like to stick with the 20" rim. Tire is 275-40-20 BFG street t/a
Re: hooking a new Challenger [Re: FastmOp] #1843602
06/07/15 07:12 PM
06/07/15 07:12 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I've got the 245 45/20 not to radial on the back of my 2012 super bee then work great the hardest part is to get 4400 lbs moving been a best so far of 12.57 I've seen others post they have been high 11s with 18 inch tires
Re: hooking a new Challenger [Re: FastmOp] #1843617
06/07/15 07:38 PM
06/07/15 07:38 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Traction control on or off?
Re: hooking a new Challenger [Re: FastmOp] #1843632
06/07/15 08:01 PM
06/07/15 08:01 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Traction control on. Turning it off is worse.
I was hoping someone had a tire recommendation, or ideas for things to address, I might lower it an inch or so. Just have no clue about the independent rearend stuff.
What's the 12.57 in the 1/8 mile. I been 7.78 but the track was flypaper.
Re: hooking a new Challenger [Re: FastmOp] #1843641
06/07/15 08:22 PM
06/07/15 08:22 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Mine had 295/40/20's on it. It was a disaster the one time I took it to RT 66. It would go sideways shifting in to 3rd gear and wheelhop like crazy with any hint of spin. I know it can be done, I've seen some pretty fast Challengers, but I was highly unsuccessful.
Re: hooking a new Challenger [Re: FastmOp] #1843681
06/07/15 09:04 PM
06/07/15 09:04 PM
Plano, TX
StricNine Offline
StricNine  Offline
Plano, TX
Stock, or no "major" build:
Manual cars: go with Hoosier slicks on 17" rims.
Auto: drag radials, MT or M&H (275r50), on 17" rims.
Nitto makes 555R in 20", but not a lot of luck with those without a big burnout, even still the 17" stuff is better and also increases effective gear ratio due to the shorter tires.
I've managed to get my 6 speed R/T to pull off mid-1.6's launching around 4200-4500 RPM.
StricNine
79 Li'l Red Express, 15.04 @ 89.57
09 Challenger R/T, 11.95 @ 115.92
Re: hooking a new Challenger [Re: FastmOp] #1843695
06/07/15 09:17 PM
06/07/15 09:17 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
I totally agree with StricNine.
Re: hooking a new Challenger [Re: FastmOp] #1843706
06/07/15 09:30 PM
06/07/15 09:30 PM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
keep the air pressure around 30psi on those short sidewall tires
Re: hooking a new Challenger [Re: FastmOp] #1844340
06/08/15 05:33 PM
06/08/15 05:33 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I'm a little over 500hp to the wheels. But 4300# is hard to launch .
With the tire I have, I'm at 38 psi for best results.
They should have fitted these pigs with some huge steam rollers.
Re: hooking a new Challenger [Re: FastmOp] #1844538
06/08/15 09:59 PM
06/08/15 09:59 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
you need more sidewall as that cushions the force to the track and provides some give. if your trying to stick 20s, then go real wide, drop the air pressure some and walk it off the line.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: hooking a new Challenger [Re: FastmOp] #1844624
06/08/15 11:29 PM
06/08/15 11:29 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
22-23 psi, quick burnout with smoke, stage and roll into the throttle quick. Been 1.91 60ft in a Charger SRT on the (worst for drag racing) stock 245 F1's
Track glue/prep matters big time - go after an event or when they have glue down.
Re: hooking a new Challenger [Re: FastmOp] #1844635
06/08/15 11:37 PM
06/08/15 11:37 PM
Home
SRT6776 Offline
SRT6776  Offline
Home
Try traction 1/2 off (hitting the button) and full off (holding down the button until it chimes) - Nitto NT55R's are a good everyday drag radial that even works in the rain.
Also, do not hit rev limit when doing burnout, it'll retard the timing and ruin your run by knocking down power - stay under 4500
Re: hooking a new Challenger [Re: FastmOp] #1844657
06/08/15 11:58 PM
06/08/15 11:58 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Would second gear be better at launch? Got a 2015 - 8 speed and there is a funny exhaust note after each shift, is that the retard you talk about? I'm dying to take to track but don't want to embarrass the car with me not knowing what to do.
Re: hooking a new Challenger [Re: cudaman1969] #1844667
06/09/15 12:09 AM
06/09/15 12:09 AM
Home
SRT6776 Offline
SRT6776  Offline
Home
The fart sound between shifts is called torque management (timing retard to lessen the blow between shifts) With it removed via tune on my 5-spd it'll pick up 3/10. Your 8spd is good for 516lb/ft - so I'd dump that (5-spd not even good for the 470lb ft of the 6.4L!)
Re: hooking a new Challenger [Re: SRT6776] #1844682
06/09/15 12:27 AM
06/09/15 12:27 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Any particular tune you recommend. I guess you mean a box?
