Re: hooking a new Challenger
[Re: FastmOp]
#1843617
06/07/15 07:38 PM
06/07/15 07:38 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Traction control on or off?
[Re: FastmOp]
#1843632
06/07/15 08:01 PM
06/07/15 08:01 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Traction control on. Turning it off is worse. I was hoping someone had a tire recommendation, or ideas for things to address, I might lower it an inch or so. Just have no clue about the independent rearend stuff.
What's the 12.57 in the 1/8 mile. I been 7.78 but the track was flypaper.
[Re: FastmOp]
#1843641
06/07/15 08:22 PM
06/07/15 08:22 PM
Posts: 20,198 Park Forest, IL
slantzilla
Park Forest, IL
Mine had 295/40/20's on it. It was a disaster the one time I took it to RT 66. It would go sideways shifting in to 3rd gear and wheelhop like crazy with any hint of spin. I know it can be done, I've seen some pretty fast Challengers, but I was highly unsuccessful.
[Re: FastmOp]
#1843681
06/07/15 09:04 PM
06/07/15 09:04 PM
Posts: 154 Plano, TX
StricNine
Plano, TX
Stock, or no "major" build:
Manual cars: go with Hoosier slicks on 17" rims. Auto: drag radials, MT or M&H (275r50), on 17" rims.
Nitto makes 555R in 20", but not a lot of luck with those without a big burnout, even still the 17" stuff is better and also increases effective gear ratio due to the shorter tires.
I've managed to get my 6 speed R/T to pull off mid-1.6's launching around 4200-4500 RPM.
StricNine
79 Li'l Red Express, 15.04 @ 89.57 09 Challenger R/T, 11.95 @ 115.92
[Re: FastmOp]
#1844624
06/08/15 11:29 PM
06/08/15 11:29 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
22-23 psi, quick burnout with smoke, stage and roll into the throttle quick. Been 1.91 60ft in a Charger SRT on the (worst for drag racing) stock 245 F1's
Track glue/prep matters big time - go after an event or when they have glue down.
[Re: FastmOp]
#1844635
06/08/15 11:37 PM
06/08/15 11:37 PM
Posts: 9,719 Home
SRT6776
Home
What's the 12.57 in the 1/8 mile. I been 7.78 but the track was flypaper. Try traction 1/2 off (hitting the button) and full off (holding down the button until it chimes) - Nitto NT55R's are a good everyday drag radial that even works in the rain. Also, do not hit rev limit when doing burnout, it'll retard the timing and ruin your run by knocking down power - stay under 4500
[Re: cudaman1969]
#1844667
06/09/15 12:09 AM
06/09/15 12:09 AM
Posts: 9,719 Home
SRT6776
Home
Would second gear be better at launch? Got a 2015 - 8 speed and there is a funny exhaust note after each shift, is that the retard you talk about? I'm dying to take to track but don't want to embarrass the car with me not knowing what to do. The fart sound between shifts is called torque management (timing retard to lessen the blow between shifts) With it removed via tune on my 5-spd it'll pick up 3/10. Your 8spd is good for 516lb/ft - so I'd dump that (5-spd not even good for the 470lb ft of the 6.4L!)
[Re: SRT6776]
#1844682
06/09/15 12:27 AM
06/09/15 12:27 AM
Posts: 8,313 fredericksburg,va
cudaman1969
fredericksburg,va
Would second gear be better at launch? Got a 2015 - 8 speed and there is a funny exhaust note after each shift, is that the retard you talk about? I'm dying to take to track but don't want to embarrass the car with me not knowing what to do. The fart sound between shifts is called torque management (timing retard to lessen the blow between shifts) With it removed via tune on my 5-spd it'll pick up 3/10. Your 8spd is good for 516lb/ft - so I'd dump that (5-spd not even good for the 470lb ft of the 6.4L!) Any particular tune you recommend. I guess you mean a box?
