front leaf mounting bolt size for A body #1843660
06/07/15 08:48 PM
06/07/15 08:48 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
What size front spring bolt should be used with cal-tracs? Spring box has a 1/2" hole but aluminum bushing in spring in much bigger. Been using 1/2" bolt but thinking maybe I should be using something bigger.
Re: front leaf mounting bolt size for A body [Re: mopar dave] #1843668
06/07/15 08:53 PM
06/07/15 08:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
5/8" in my Calvert monos.
Re: front leaf mounting bolt size for A body [Re: justinp61] #1843673
06/07/15 09:00 PM
06/07/15 09:00 PM
Mt Morris Michigan
Mt Morris Michigan
I use Calvert monos as well. Didn't measure the bolt hole in the aluminum bushing but it looks like it might be 3/4" opening.
Re: front leaf mounting bolt size for A body [Re: mopar dave] #1843745
06/07/15 10:03 PM
06/07/15 10:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'll double check mine tomorrow.
Re: front leaf mounting bolt size for A body [Re: mopar dave] #1844206
06/08/15 02:12 PM
06/08/15 02:12 PM
AndyF Offline
AndyF  Offline
Stock A body hangers can be 1/2 or 9/16 or 5/8 bolt size. The aftermarket stuff is all 5/8 bolt size.
Re: front leaf mounting bolt size for A body [Re: AndyF] #1844215
06/08/15 02:20 PM
06/08/15 02:20 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks Andy. I'll get some 5/8 bolts.
Re: front leaf mounting bolt size for A body [Re: mopar dave] #1844258
06/08/15 03:23 PM
06/08/15 03:23 PM
CA
crackedback Offline
crackedback  Offline
CA
If you want to use the size you have, call calvert and ask them for the correct sized steel pivot sleeve. They have them.
Re: front leaf mounting bolt size for A body [Re: crackedback] #1844279
06/08/15 03:41 PM
06/08/15 03:41 PM
Mt Morris Michigan
Mt Morris Michigan
thanks. ill give them a call.
