front leaf mounting bolt size for A body #1843660
06/07/15 08:48 PM
06/07/15 08:48 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What size front spring bolt should be used with cal-tracs? Spring box has a 1/2" hole but aluminum bushing in spring in much bigger. Been using 1/2" bolt but thinking maybe I should be using something bigger.
Re: front leaf mounting bolt size for A body [Re: mopar dave] #1843668
06/07/15 08:53 PM
06/07/15 08:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
5/8" in my Calvert monos.
Re: front leaf mounting bolt size for A body [Re: justinp61] #1843673
06/07/15 09:00 PM
06/07/15 09:00 PM
Mt Morris Michigan
Mt Morris Michigan
I use Calvert monos as well. Didn't measure the bolt hole in the aluminum bushing but it looks like it might be 3/4" opening.
Re: front leaf mounting bolt size for A body [Re: mopar dave] #1843745
06/07/15 10:03 PM
06/07/15 10:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'll double check mine tomorrow.
Re: front leaf mounting bolt size for A body [Re: mopar dave] #1844206
06/08/15 02:12 PM
06/08/15 02:12 PM
AndyF Offline
AndyF  Offline
Stock A body hangers can be 1/2 or 9/16 or 5/8 bolt size. The aftermarket stuff is all 5/8 bolt size.
Re: front leaf mounting bolt size for A body [Re: AndyF] #1844215
06/08/15 02:20 PM
06/08/15 02:20 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks Andy. I'll get some 5/8 bolts.
Re: front leaf mounting bolt size for A body [Re: mopar dave] #1844258
06/08/15 03:23 PM
06/08/15 03:23 PM
CA
crackedback Online content
crackedback  Online Content
CA
If you want to use the size you have, call calvert and ask them for the correct sized steel pivot sleeve. They have them.
Re: front leaf mounting bolt size for A body [Re: crackedback] #1844279
06/08/15 03:41 PM
06/08/15 03:41 PM
Mt Morris Michigan
Mt Morris Michigan
thanks. ill give them a call.
