Re: Best rear springs for 66 Valiant Wagon w/440" sbm?
[Re: Streetwize]
#1843526
06/07/15 05:22 PM
06/07/15 05:22 PM
Posts: 31,050 Oregon
AndyF
SS springs will work if you use a couple of left side springs. Or go with the road race springs. The road race springs require a slightly shorter hanger. You can buy the complete setup from www.firmfeel.comI wouldn't put a set of standard SS springs on there since they'll make the car sit funny. But it works okay if you order them individually and go with a pair of driver side springs. XHD springs might work but you'll probably need a pair of kicker shocks to keep it from wrapping up. Firm Feel has the kicker shock setup if you want to go that way.
[Re: AndyF]
#1843541
06/07/15 05:32 PM
06/07/15 05:32 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Thanks andy,
Yeah i know the 02/03's are staggered and make the car list to one side. I want the car to ridenice and handle well ( for what it is)
[Re: AndyF]
#1843881
06/08/15 12:23 AM
06/08/15 12:23 AM
RapidRobert
For the record which is better, a pair of 002's or 003's. I bought a 65 dart roller with 003/003's & when done it rode high and tight (I was happy), real nice and firm. just needed shock extensions to finish up
[Re: Streetwize]
#1845201
06/09/15 08:07 PM
06/09/15 08:07 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If I recall correctly, I had the lightest springs (2800)in my Dart way back when, and the wheelbase was moved forward 6 inches as well. It had a lot of rise, probably running out of shock length even with the long shocks. Just an opinion, but I figure the more rise the better on both ends for a street car if you want max traction. The picture is of my Dart running low tens, way back when!
