440 race street motor #184231
01/04/09 10:42 PM
01/04/09 10:42 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
We ran at the track yesterday. The car did fine until we got to the top of second gear and all the way through third there was a very slight miss just enough to here it. We can't find anything wrong don't know if it is gas or fire. Has anyone had anything like this before. The motor has all msd ignition it is a mild 440 with around 11 to 1 comp. 557 solid cam 1150 dominator.It has a torqueflite. What do you think?
Re: 440 race street motor [Re: bobs69] #184232
01/04/09 10:48 PM
01/04/09 10:48 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I'm no guru but with the displacement and cam you stated I'ld say you have to big a carb on it.
Re: 440 race street motor [Re: WILD BILL] #184233
01/04/09 11:06 PM
01/04/09 11:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My mild 440 has the .557 cam with 906 heads and 10.0 comp. I use a basic 850 DP on it and it seems to work fine. I agree it seems like alot of carb for it but cant say if thats your problem. Misses are very hard to diagnose on the puter. Ron
Re: 440 race street motor [Re: bobs69] #184234
01/04/09 11:28 PM
01/04/09 11:28 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
is the miss still there? that happened to me once and scared the poop out of me as i was an 8 hour drive from home. turns out my timing tape flew off and got sucked into the carb (ran without air cleaner)
Re: 440 race street motor [Re: 383man] #184235
01/04/09 11:32 PM
01/04/09 11:32 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Could be a fuel supply problem. That dom may be wanting more fuel than its getting. That, said, i ran a dom with just a carter mech pump and 3/8" line in a 550 hp 440 Challenger and it worked fine.
Re: 440 race street motor [Re: dirtybee] #184236
01/04/09 11:36 PM
01/04/09 11:36 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
It did the same every pass. We were thinking if the carb was too big it will show up more off the line at lower rpm!
Re: 440 race street motor [Re: bobs69] #184237
01/04/09 11:41 PM
01/04/09 11:41 PM
MN
hemidup Offline
hemidup  Offline
MN
It sounds like a fuel issue. May I ask what size fuel line your running?
Jerry Williams.
Re: 440 race street motor [Re: hemidup] #184238
01/04/09 11:46 PM
01/04/09 11:46 PM
Brisbane Australia
572B1 Online content
572B1  Online Content
Brisbane Australia
Is the carb up through the bonnet and are you running a scoop.
Re: 440 race street motor [Re: hemidup] #184239
01/04/09 11:47 PM
01/04/09 11:47 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
We run holley blue pump half inch line six pound of pressure.
Re: 440 race street motor [Re: 572B1] #184240
01/04/09 11:48 PM
01/04/09 11:48 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
He means HOOD
Ron, That was my thinking as well. I have basicly the same motor w/ less CR and Eddy heads and run a 750 DP. Did you set the fule presss W/ the engine running? Try bumping it up to 7 1/2 or 8 psi and see what happens.
Re: 440 race street motor [Re: WILD BILL] #184241
01/04/09 11:51 PM
01/04/09 11:51 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
We do run a scoop
Re: 440 race street motor [Re: bobs69] #184242
01/05/09 12:01 AM
01/05/09 12:01 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I had amiss once that turned out to be a dirty filter...just sounds like after going thru first and top of 2nd, that your fuel system is not overcoming the enertia thats trying to push the fuel in the line back.
Re: 440 race street motor [Re: bobs69] #184243
01/05/09 12:04 AM
01/05/09 12:04 AM
Brisbane Australia
Brisbane Australia
We do run a scoop
The reason I asked,I have seen cars with a carb above the bonnet line and no scoop, that get reversion out the carb.
PS I mean hood dam yanks.lol
Re: 440 race street motor [Re: 572B1] #184244
01/05/09 12:25 AM
01/05/09 12:25 AM
SW pa
goldenlancer Offline
SW pa
could it be lean?
N/SS
Re: 440 race street motor [Re: bobs69] #184245
01/05/09 12:39 AM
01/05/09 12:39 AM
Bingo, the old Holley blue is probally not up to the task that your asking it to do Can you and did you look at the fuel pressure wghen it was missing? If so what was it reading. Did you look at the spark plugs at all? If so what color are they and when did you look at them, in the pits after the run or at the end of the track after the run without driving it back to the pits.? Give us some more information off of the time slip, 60 ft. times, 330 times and MPH 660 ft, ET and MPH and the rest to times off of the time slips that it missed on. You can take a Ohm meter and check the spark plug wires also, I had a 440 motor that would miss slightly only in high gear above 5000 rpms which ended up being three spark plug wires going bad, to high of resistance for the MSD 7C to fire lots of things can cause a miss in the motor, some of them are easy to find like broken spark plug or a spark plug wire vibrated off and others can be a real bear to find Good luck, please let us know what you find and post that back on here Lots of people on here learn from each other
Re: 440 race street motor [Re: Cab_Burge] #184246
01/05/09 08:42 AM
01/05/09 08:42 AM
Pittsburgh, PA
bobdog106 Offline
bobdog106  Offline
Pittsburgh, PA
I had a miss in upper RPM's and Rick from Firecore custom made a set at the Mopar Nats. No more miss fire plus he is a member here.
Re: 440 race street motor [Re: Cab_Burge] #184247
01/05/09 11:26 AM
01/05/09 11:26 AM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
I ran a very similar combo in my, otherwise stock '69 Road Runner. I could give you my exact incremental info from a number of runs. I was running a Weiand CH4B intake with no spacer. I ran in the 12.40's on most passes. The car had 4.30 gears and a 3500 RPM Converter. When I swapped to a friend's sorted out 6-pak, the car went 12.11.
May I suggest you check the float level in the carbs bowls? If the float level is too low, you will see the problem you ran into. If they are too high, the car will act strange as well. Set the floats. If you have 6 pounds of fuel pressure you should be in good shape. Make sure the 6 PSI is achieved while going through the traps. Good luck.
Re: 440 race street motor [Re: Tommy D] #184248
01/05/09 11:30 AM
01/05/09 11:30 AM
Tommy D Offline
Tommy D  Offline
One more thing...What timing are you running? Check to make sure the timing is actually where you want it to be.
If it spits through the carb...it's an ignition thing.
If it spits out the exhaust...it's the carb.
Try bolting on a friend's working carb, or carb/intake combo. That cured a ton of my problems. Tom
Re: 440 race street motor [Re: goldenlancer] #184249
01/05/09 11:48 AM
01/05/09 11:48 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
could it be lean?
Bill I think your on to something.It may be too lean since he passing so much air through that 1150 and max jet is #100 or .125. Try a 1050.
Re: 440 race street motor [Re: B G Racing] #184250
01/05/09 11:59 AM
01/05/09 11:59 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
could it be lean?
I'm no expert by a long shot but sounds like either a lean condition or eletronics problem. I had the same thing happen to a 383 dart pulled like a mofo thru 2nd then would stumble down track. Jetted up by 2 until the problem was sovled.
