E Body Rear Frames - Difference - AMD vrs GOODMARK #1841875
06/05/15 01:08 AM
06/05/15 01:08 AM
michigan
440whiteboy Offline OP
michigan
not sure if anyone has posted this before?
E Body rear full frames Review -
I have pictures to show the two side by side to compare
of both AMD - and Goodmark -
close up's to show the very different features.
AMD is the dusty one on the right.
goodmans gusset plate's are not square through out the whole piece - left side of both pics.
the form of amd is clean and sharp on the bottom right,
stamping is defined.
Its seems that goodman's quality produces second's of their product?
They only see Stars...
when hit by a Mopar!
Re: E Body Rear Frames - Difference - AMD vrs GOODMARK [Re: 440whiteboy] #1841880
06/05/15 01:09 AM
06/05/15 01:09 AM
michigan
michigan
amd is stronger with the welds and the form of the end plates on the right.
goodman on the left front corner fold is way off of a 1/4" away from
the main body??? not even close for a weld... makes one think about the inspection process?
Re: E Body Rear Frames - Difference - AMD vrs GOODMARK [Re: 440whiteboy] #1841881
06/05/15 01:10 AM
06/05/15 01:10 AM
michigan
michigan
inside screw backing plates of each.
Amd on right and the bottom pic shows extra running welds on the short edges of the plate - plus its thicker for the screw threads for holding.
goodmans plate is floating - not centered with 3 small tack like welds.
Re: E Body Rear Frames - Difference - AMD vrs GOODMARK [Re: 440whiteboy] #1841882
06/05/15 01:11 AM
06/05/15 01:11 AM
michigan
michigan
close ups of the rear end plates
Amd - top pic
Goodman - bottom pic
one can see how the welds are thicker and deeper of amd
Re: E Body Rear Frames - Difference - AMD vrs GOODMARK [Re: 440whiteboy] #1841886
06/05/15 01:24 AM
06/05/15 01:24 AM
michigan
michigan
more pics to follow
Re: E Body Rear Frames - Difference - AMD vrs GOODMARK [Re: 440whiteboy] #1841981
06/05/15 09:36 AM
06/05/15 09:36 AM
michigan
michigan
more views -
right pic is amd
left and bottom is goodman showing rippling of top edge metal.
weld on pipe shackle hanger view is only front 1/3 coverage -
Re: E Body Rear Frames - Difference - AMD vrs GOODMARK [Re: 440whiteboy] #1841983
06/05/15 09:41 AM
06/05/15 09:41 AM
michigan
michigan
pipe tube for shackle hanger
top pic goodman only welds apx. 1/3 in front of the pipe a thin bead.
bottom pic -
amd welds all the way around with a thick weld.
Re: E Body Rear Frames - Difference - AMD vrs GOODMARK [Re: 440whiteboy] #1842005
06/05/15 10:43 AM
06/05/15 10:43 AM
michigan
michigan
With these two frames I have - it seems in comparison that
AMD - is a better product all the way around with just about every feature!
I noticed that amd the welds are deeper - larger and the placement is better.
goodman's welds look like a quick pinch weld type hit?
Amd spends more money on the weld process using more electricity on a longer cycle using more wire.
To me this means over time AMD would stand way longer as originals did.
The metal seems stronger when running self tapping screws into both of them.
The gusset - web pieces are thicker with amd.
The back screw plates are thicker and welded deeper with amd.
The main overall appearance is better - top flanges don't have ripples in the AMD.
GOODMAN -
without totally bashing Goodman - they are good for the lower budget job - and better than the old rusty pieces!
They are thick metal. For the most part, the form seems good for fitment.
The length seems the same for both.
They both weld nice when installing.
twocents
Re: E Body Rear Frames - Difference - AMD vrs GOODMARK [Re: 440whiteboy] #1984770
01/06/16 10:14 AM
01/06/16 10:14 AM
tboomer Offline
tboomer  Offline
bump
