a833 o.d. best oil #1838956
06/01/15 06:15 PM
06/01/15 06:15 PM
Tipp City, Ohio
Backfire Offline OP
Backfire  Offline OP
Tipp City, Ohio
would the syncromesh or syncromax fluids that came out in the 90's be better for the 833 o.d. than 80w-90 hypoid gear oil or ATF ?
'68 Charger R\T
Re: a833 o.d. best oil [Re: Backfire] #1839140
06/01/15 08:27 PM
06/01/15 08:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have used syncromesh with good results , I would never run ATF in any 833 I cared about .
Re: a833 o.d. best oil [Re: Backfire] #1839154
06/01/15 08:40 PM
06/01/15 08:40 PM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
[quote=Backfire]would the syncromesh or syncromax fluids that came out in the 90's be better for the 833 o.d. than 80w-90 hypoid gear oil or ATF ?[I've always used 80-90 but... somebody convince us./quote]
Re: a833 o.d. best oil [Re: Backfire] #1840400
06/03/15 12:13 PM
06/03/15 12:13 PM
Alberta
rustbuckett68 Offline
Alberta
Mopar recommends ATF. I ran it in my 833OD and it was a good shifter, even in the winter.
Re: a833 o.d. best oil [Re: Backfire] #1840419
06/03/15 12:49 PM
06/03/15 12:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you do a search on here you will find a lot of threads on this subject and a lot of differing opinions. But there are a few things that the service manuals tell you. First, GL-5 is for differentials and is not the best choice for your tranny. Especially the GL-5 with Sure-Grip or Limited Slip additive. That was true 50 years ago and is still true today. Now that doesn't mean that putting Gl-5 in your tranny will smoke it, it just means that it is not formulated for it.
GL-4 is the lube designation you want for your tranny. And it can be difficult to find nowadays. And there are different weights of it, too. Correct me if I am wrong, but I think that our trannies want 80/90. The last time I had to find some, all I could find was 140. The tranny shifted real stiff with it, so I just kept cutting the gear oil with ATF until it shifted smooth, Ended up about 50/50 ATF and 140 GL-4.
I think if you look in the original service manuals, ATF was called for in colder climates. I personally do not like straight ATF for summer driving, but I am sure that someone will disagree. For me, a GL-4 with a viscosity that is not difficult to shift until it warms up is the way to go.
Master, again and still
Re: a833 o.d. best oil [Re: DaveRS23] #1840480
06/03/15 02:11 PM
06/03/15 02:11 PM
dogdays Offline
dogdays  Offline
Pretty well thought out.
The GL-4 or GL-5 indicates the type of additive package in the oil.
GL-4 additive is anti-wear, sometimes there would be an AW in the nomenclature of the oil. It uses molecules that attach to the surfaces. In the beginning these Anti-Wear additives were made from tallow.
GL-5 was developed for the sliding friction that came into being with the invention of hypoid gears, sometime in the '30s, IIRC. These additives microscopically attack the surface of the gears and create an oxide layer. Under high loads, when the oil film is ruptured, the oxide layers on the gears prevent metal-to-metal contact and prevent the contact welding that would occur otherwise. The oxide layers are the last line of defense.
The chemically active additive packages work more aggressively on copper alloys, like the parts of the synchronizers made of brass or bronze. They also prevent the synchronizers from doing their job, which involves a certain amount of friction needed to match speeds between driving and driven parts. So use of the GL-5 oil can cause hard shifting.
There are several manufacturers of manual transmission lubricants that are GL-4. Redline's MTL is a prime example, but there are quite a few others. The problem of high viscosity on cold startup is solved by using a synthetic that has a much flatter viscosity vs. temperature curve. My friend who was an EMT in a high mountain town did that 30 years ago, although at that time there were only a handful of synthetic gearlubes generally used in the Arctic regions. But when he got a call when the temperature were 30 below, his 4wd was ready to go and there was actually lubricant flowing in the transmission and differentials.
One last thing.....Viscosity numbers assigned by the SAE are NOT the same for motor oils and gear oils. They were assigned different ranges of numbers to avoid confusion. So, 90 gear oil is about the same viscosity as 40 motor oil. If you already knew this, you're ahead of the game.
R.
Re: a833 o.d. best oil [Re: Backfire] #1840763
06/03/15 07:51 PM
06/03/15 07:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Syncromesh says right on the bottle that it is for use in transmissions with BRASS rings ...
Re: a833 o.d. best oil [Re: JohnRR] #1841069
06/04/15 12:34 AM
06/04/15 12:34 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree ATF just doesn't have the lubrication quality that a good quality gear lube has. Jamie Passon offers a good blend specifically made for Mopar manual transmissions.
Gus beer
64 Plymouth Savoy
Dana 60
Re: a833 o.d. best oil [Re: Backfire] #1841096
06/04/15 01:04 AM
06/04/15 01:04 AM
AndyF Offline
AndyF  Offline
I use Redline MTL
http://www.redlineoil.com/product.aspx?product=50204
But I'd also trust anything that Jamie had for sale or anything that Brewer's recommended. I just got hooked up with Redline years ago and haven't had any reason to switch away. My Doug Nash shifts better with MTL than anything else I've run in it.
Re: a833 o.d. best oil [Re: JohnRR] #1841235
06/04/15 10:08 AM
06/04/15 10:08 AM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Interesting thread.
Im just finishing a rebuilt 4 speed in my 65 Coronet.
I added a GL5 90 weight.
I have about 5 miles on Car.
Can I just drain and refill with 75/80 GL4?
Or is a cleaner needed?
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: a833 o.d. best oil [Re: 440PURSUIT] #1841281
06/04/15 11:26 AM
06/04/15 11:26 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Transmission oil is like engine oil and most every thing else,"ours is better than theirs" depending or what you read/hear.Find out what the manufacturer recommends,they spent millions on R&D. twocents
Re: a833 o.d. best oil [Re: 440PURSUIT] #1841409
06/04/15 01:54 PM
06/04/15 01:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By 440PURSUIT
Interesting thread.
Sure can , there will be a small residual amount left inside and that shouldn't really matter. Let it drain overnight .
Re: a833 o.d. best oil [Re: Backfire] #1841687
06/04/15 08:45 PM
06/04/15 08:45 PM
usa
smos001 Offline
smos001  Offline
usa
Last year I called valvoline on this question.
They stated that GL5 is not recommended for transmissions with yellow metal in them such as 833. They suggested GL4. GL5 will erode brass.
Re: a833 o.d. best oil [Re: Backfire] #1841694
06/04/15 08:49 PM
06/04/15 08:49 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
In 1973 the recommended Tranny oil ( per the service station manual and the auto parts supply store) for my 18 spline was 140wt..
That's what I refilled it with after installing a new front bearing cover..It was HORRIBLE shifting.....
Re: a833 o.d. best oil [Re: 440PURSUIT] #1841869
06/05/15 01:02 AM
06/05/15 01:02 AM
IN
ahy Offline
ahy  Offline
IN
I wouldn't think a cleaner is necessary. Just let it drain for a while. A little left over should not hurt
I also have had good luck with Redline MTL and Redline MT90 in several MT's though not 833's. Personally I would pick the MT90 for an 833 run in warmer weather. Should not do too bad in cold weather either.
