a833 o.d. best oil
#1838956
06/01/15 06:15 PM
06/01/15 06:15 PM
Posts: 182 Tipp City, Ohio
Backfire
Tipp City, Ohio
would the syncromesh or syncromax fluids that came out in the 90's be better for the 833 o.d. than 80w-90 hypoid gear oil or ATF ?
'68 Charger R\T
Re: a833 o.d. best oil
[Re: Backfire]
#1840419
06/03/15 12:49 PM
06/03/15 12:49 PM
Posts: 12,071 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you do a search on here you will find a lot of threads on this subject and a lot of differing opinions. But there are a few things that the service manuals tell you. First, GL-5 is for differentials and is not the best choice for your tranny. Especially the GL-5 with Sure-Grip or Limited Slip additive. That was true 50 years ago and is still true today. Now that doesn't mean that putting Gl-5 in your tranny will smoke it, it just means that it is not formulated for it.
GL-4 is the lube designation you want for your tranny. And it can be difficult to find nowadays. And there are different weights of it, too. Correct me if I am wrong, but I think that our trannies want 80/90. The last time I had to find some, all I could find was 140. The tranny shifted real stiff with it, so I just kept cutting the gear oil with ATF until it shifted smooth, Ended up about 50/50 ATF and 140 GL-4.
I think if you look in the original service manuals, ATF was called for in colder climates. I personally do not like straight ATF for summer driving, but I am sure that someone will disagree. For me, a GL-4 with a viscosity that is not difficult to shift until it warms up is the way to go.
Master, again and still
[Re: DaveRS23]
#1840480
06/03/15 02:11 PM
06/03/15 02:11 PM
dogdays
Pretty well thought out.
The GL-4 or GL-5 indicates the type of additive package in the oil. GL-4 additive is anti-wear, sometimes there would be an AW in the nomenclature of the oil. It uses molecules that attach to the surfaces. In the beginning these Anti-Wear additives were made from tallow.
GL-5 was developed for the sliding friction that came into being with the invention of hypoid gears, sometime in the '30s, IIRC. These additives microscopically attack the surface of the gears and create an oxide layer. Under high loads, when the oil film is ruptured, the oxide layers on the gears prevent metal-to-metal contact and prevent the contact welding that would occur otherwise. The oxide layers are the last line of defense.
The chemically active additive packages work more aggressively on copper alloys, like the parts of the synchronizers made of brass or bronze. They also prevent the synchronizers from doing their job, which involves a certain amount of friction needed to match speeds between driving and driven parts. So use of the GL-5 oil can cause hard shifting.
There are several manufacturers of manual transmission lubricants that are GL-4. Redline's MTL is a prime example, but there are quite a few others. The problem of high viscosity on cold startup is solved by using a synthetic that has a much flatter viscosity vs. temperature curve. My friend who was an EMT in a high mountain town did that 30 years ago, although at that time there were only a handful of synthetic gearlubes generally used in the Arctic regions. But when he got a call when the temperature were 30 below, his 4wd was ready to go and there was actually lubricant flowing in the transmission and differentials.
One last thing.....Viscosity numbers assigned by the SAE are NOT the same for motor oils and gear oils. They were assigned different ranges of numbers to avoid confusion. So, 90 gear oil is about the same viscosity as 40 motor oil. If you already knew this, you're ahead of the game.
R.
[Re: JohnRR]
#1841069
06/04/15 12:34 AM
06/04/15 12:34 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have used syncromesh with good results , I would never run ATF in any 833 I cared about . ATF just doesn't have the lubrication quality that a good quality gear lube has. Jamie Passon offers a good blend specifically made for Mopar manual transmissions. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Backfire]
#1841096
06/04/15 01:04 AM
06/04/15 01:04 AM
Posts: 31,021 Oregon
AndyF
I use Redline MTL http://www.redlineoil.com/product.aspx?product=50204But I'd also trust anything that Jamie had for sale or anything that Brewer's recommended. I just got hooked up with Redline years ago and haven't had any reason to switch away. My Doug Nash shifts better with MTL than anything else I've run in it.
[Re: JohnRR]
#1841235
06/04/15 10:08 AM
06/04/15 10:08 AM
Posts: 1,548 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Interesting thread.
Im just finishing a rebuilt 4 speed in my 65 Coronet. I added a GL5 90 weight. I have about 5 miles on Car.
Can I just drain and refill with 75/80 GL4?
Or is a cleaner needed?
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger w 383 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1997 Ram B3500 Van 5.9 1991.5 W250 Cummins- Big Chief
[Re: 440PURSUIT]
#1841409
06/04/15 01:54 PM
06/04/15 01:54 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Interesting thread.
Thanks Sure can , there will be a small residual amount left inside and that shouldn't really matter. Let it drain overnight .
