Powermaster alternators
#1841402
06/04/15 01:47 PM
06/04/15 01:47 PM
Posts: 1,532 off the grid
340B5
off the grid
Anybody running Powermaster alternators like them and had them last.
Yeah, it's got a smallblock.
Re: Powermaster alternators
[Re: 340B5]
#1841406
06/04/15 01:51 PM
06/04/15 01:51 PM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
Been running the same 100 amp Powermaster on my cuda since 2006. Works good, although I'd like to have a little more output.
[Re: an8sec70cuda]
#1841441
06/04/15 02:32 PM
06/04/15 02:32 PM
Posts: 452 new york usa
pattyboy 572
new york usa
Have power master 8142 since 2005,needed rebuild and shaft replaced last year, they sold me a brand new one for approx.. 180.00 with shipping(that's about50% of a new one with shipping) john in returns is great to work with. pat (I also run there starter)
[Re: 340B5]
#1841448
06/04/15 02:43 PM
06/04/15 02:43 PM
Challenger 1
Cincinnati, Ohio
Anybody running Powermaster alternators like them and had them last. I have 2 of them, one since 2005, works great. 100 amps or so.
[Re: 340B5]
#1841456
06/04/15 02:53 PM
06/04/15 02:53 PM
340B5
off the grid
Thanks guys, just wanted to do a quality check before pulling the trigger.
BTW I talked to Powermaster and the Alt. listed as a 75 amp is actually a 90 amp. He said they haven't made a 75 amp for 3 or 4 years, so I'll be buying the 75 which should do the job and most likely getting a 90A.
[Re: 340B5]
#1841506
06/04/15 04:04 PM
06/04/15 04:04 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I had the #7508 (75a: 60a idle and 99a max. As you mentioned, no longer made) for 3 years then it stopped charging at idle. I feel that it should have lasted longer than it did. Recently I decided to buy another Powermaster unit again and now I am running their new Chrysler Upgrade 165 series alternator. I agree that their customer service is excellent. I was able to speek with a sales rep and an engineer before deciding which unit to purchase.
Note: I have read that you should not exceed 75% of the alternators capacity at idle, or it will get hot and shorten its life. I suggest before you buy, double check your idle amperage needs and add 25% for your "minimum" idle requirement when buying a new unit.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
