Jet Change Tips at a TNT day #184134
01/04/09 09:18 PM
01/04/09 09:18 PM
U.S.
moparniac Offline OP
U.S.
When I get to the track next summer I am going to mess with jets... what do you guys recomend having handy parts wise and or tips.. thx
Mopar Performance
Re: Jet Change Tips at a TNT day [Re: moparniac] #184135
01/04/09 09:26 PM
01/04/09 09:26 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Spare float bowl gaskets...or rub some vaseline on the gaskets next time you have the bowl off.
Re: Jet Change Tips at a TNT day [Re: toddd] #184136
01/04/09 09:35 PM
01/04/09 09:35 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
I use chap stick on the gaskets. And don't forget something to drain the bowls into.
Re: Jet Change Tips at a TNT day [Re: moparniac] #184137
01/04/09 09:46 PM
01/04/09 09:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Remember your jetting for MPH, I like to jet up 2
jet sizes at a time till you peak MPH then back down
1 jet size and see what it does
Re: Jet Change Tips at a TNT day [Re: MR_P_BODY] #184138
01/04/09 09:49 PM
01/04/09 09:49 PM
U.S.
U.S.
are really just jetting the main jets....
Mopar Performance
Re: Jet Change Tips at a TNT day [Re: moparniac] #184139
01/04/09 09:56 PM
01/04/09 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont understand the question. If you are asking if
you just jet the mains, well you have the pri and sec
jets(is this a Holley)
Re: Jet Change Tips at a TNT day [Re: moparniac] #184140
01/04/09 10:02 PM
01/04/09 10:02 PM
You should change the main jets, I do both the primarys and secondarys at the same time unless I see a need for staggered jetting, for the mph and then do any fine tuning on the HS bleeds. I normally start on the idle circiuts before I do any main jet changing and the same on the accelerator pump circiuts and squirters, in other words I do the idle and staring line first and do the main jets lasts
Re: Jet Change Tips at a TNT day [Re: Cab_Burge] #184141
01/04/09 10:09 PM
01/04/09 10:09 PM
U.S.
U.S.
sorry its a 1050 dominator
Mopar Performance
Re: Jet Change Tips at a TNT day [Re: moparniac] #184142
01/04/09 10:27 PM
01/04/09 10:27 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
A bunch of handy rags in case of a spill. And a catch device for fuel drainage. Plus all of the above already stated. mike
Re: Jet Change Tips at a TNT day [Re: moparniac] #184143
01/04/09 11:37 PM
01/04/09 11:37 PM
Locomotion Offline
Locomotion  Offline
I like to change jetting the same amount all around from what the carb was made with. Unless you are really good at reading plugs and/or know how your fuel distribution is, I figure it's best to keep the "balance" Holley set it up with.
Accellerator pump squirters and cams will help tune your 60' & 330' times, especially if the jetting changes that help mph end up hurting '60. What's optimum on the top end can richen or lean out your launch air/fuel ratio.
A Holley tuning book can also be helpful with tuning tips, pump cam specs, etc. I like the one by HPBooks.
Re: Jet Change Tips at a TNT day [Re: Locomotion] #184144
01/04/09 11:50 PM
01/04/09 11:50 PM
U.S.
U.S.
do they have one for a dominator?
Mopar Performance
Re: Jet Change Tips at a TNT day [Re: moparniac] #184145
01/05/09 12:09 AM
01/05/09 12:09 AM
Locomotion Offline
Locomotion  Offline
Those books cover all the Holley carbs and the tuning tips are basically the same for all. I never did get into air bleed modifications. But it's best to figure out the jetting, squirters, pump cams, power valve (if any), etc. first.
I think this is the latest edition: Holley reference book by HPBooks @ Summit.
There are a few others out there.
....and do have a fire extinguisher handy. Trust me, you never know when you might develop a leak or forget to tighten something!
Re: Jet Change Tips at a TNT day [Re: Locomotion] #184146
01/05/09 12:34 AM
01/05/09 12:34 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I use a spray paint can cap for jet changes. The right cap will almost catch all of the fuel out of the bowl.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Jet Change Tips at a TNT day [Re: Von] #184147
01/05/09 02:31 AM
01/05/09 02:31 AM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
A heli-coil kit.....don't ask.
