Re: 69 Dart GTS Tail panel mounting holes
[Re: mopfried]
#1840222
06/03/15 01:27 AM
06/03/15 01:27 AM
Posts: 43,626 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I used to have the measurements, but my filing system leaves a lot to be desired. ![eyes eyes](/ubbthreads/images/graemlins/custom/eyes.gif) I will see what I an find. If worse comes to worse I can always measure them again. ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif) You can always measure your tail panel and drill accordingly...
JB Rhinehart, Realist
A-Body's RULE!
[Re: mopfried]
#1841341
06/04/15 12:44 PM
06/04/15 12:44 PM
Posts: 738 Columbus Ohio
mopfried
Columbus Ohio
I don't have any pics with me here at work, but they were supplied by a well know Mopar vendor R/T specialties. they have a little longer stud than the original is what I'm told. The clip has a little wire hanging off it. I need to put the clips onto the panel in order to get it on. That don't seem right at all. With the metal piece that the stud comes out of there would be no way to mount the clip then hang the panel. that why I think the holes are too far apart.
[Re: mopfried]
#1842123
06/05/15 02:11 PM
06/05/15 02:11 PM
Rhinodart
Rhinotruck
Rhinotruck
They will probably work but the 4 clips on the sides used 5/16" nuts instead of the 3/8" sheetmetal nuts the other clips use.
A-Body's RULE!
[Re: mopfried]
#1843293
06/07/15 10:20 AM
06/07/15 10:20 AM
Posts: 10,759 North Dakota
6PakBee
North Dakota
My memory isn't failing me! At least not this time. I thought I had saved a post from a couple years ago from Rhino on this very subject. I had and this is it.
"I have not found but a couple of the clips at this point. I did check two trunk lids and recorded the measurements, but of course it is more complicated to explain than I thought. I started from the left top corner and measured to the right. They are 1/4" holes and the first one starts 5/8" from the edge and 1-1/2" down. The next one down is 4-7/8". The top row from the first hole is 4-5/8", 9-3/4", 9-3/4", 9-3/4" and the last hole is also 5/8" from the top right edge with the hole below it at 4-7/8". The bottom row holes from the left bottom hole is 9-1/4", 7-3/4", 10-3/4", 7-3/4", and 7-3/4". Of course you can approximate and check the hole spacing by turning your panel over and reversing the dimensions. Not to worry, I was a Mechanical Designer in a previous lifetime and double-checked my findings. I will see if I can dig-up more of the clips."
