Re: Help - Lost Electrical Power to Circuits
[Re: stumpy]
#1840644
06/03/15 04:59 PM
06/03/15 04:59 PM
RapidRobert
What Stump said, pull the bulkhead start checking continuities & if it is the FL find/fix the high draw/dead short that fried it
[Re: duckblind]
#1841156
06/04/15 03:10 AM
06/04/15 03:10 AM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
As others have said I bet its either in the bulkhead, or the ammeter is failed. Either one is very common, and easy to locate just take a light and poke around till you find where you lose power somewhere...
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
