Slowing down for a index class...........
#1839466
06/02/15 02:05 AM
06/02/15 02:05 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Ok , my best ET this year was a 6.21. I have been thinking about trying index racing at one of my local tracks. They have 6.0,7.0,8.0 and 9.0. I am too slow for 6.0 and wondering if I can slow down enough to run 7.00. I would think I need full throttle to cut a decent reaction time on the 4 tenths pro tree,I am foot braking. This Wednesday I am going to T&T and try to figure out if I can slow down enough to run 7.00. Is it possible to lower my shift point enough to run 7.00. I shift at 6800 rpm now and I have a 5800 rpm chip I am going to try. Does any body have any ideas?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Slowing down for a index class...........
[Re: D-50]
#1839482
06/02/15 03:03 AM
06/02/15 03:03 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
[Re: J_BODY]
#1839483
06/02/15 03:06 AM
06/02/15 03:06 AM
D-50
North, Alabama
Thanks for the reply but I am not spending anywhere near that kind of money to slow down . I could put that money on going 6.0.
[Re: D-50]
#1839551
06/02/15 09:24 AM
06/02/15 09:24 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Foot braking on a 4 tenths tree is bringing a knife toa gun fight. Adding in slowing down that much just compounds the problem. I would probably find something else to do, or run a brake
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: D-50]
#1839609
06/02/15 11:52 AM
06/02/15 11:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
What I did to slow my car down from 9.0 to 10.0 was make a mech throttle stop(pic) and changed the launch rpm and shift rpm.. was deadly on 10.0 if I could catch the light.. this was on a trans brake
[Re: MR_P_BODY]
#1839618
06/02/15 12:06 PM
06/02/15 12:06 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
What I did to slow my car down from 9.0 to 10.0 was make a mech throttle stop(pic) and changed the launch rpm and shift rpm.. was deadly on 10.0 if I could catch the light.. this was on a trans brake That's the right way to do it. Or you could just fill the bed up with railroad ties. If anybody says anything just tell them you were using your truck to do some landscaping.
[Re: D-50]
#1839627
06/02/15 12:13 PM
06/02/15 12:13 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Ok , my best ET this year was a 6.21. I have been thinking about trying index racing at one of my local tracks. They have 6.0,7.0,8.0 and 9.0. I am too slow for 6.0 and wondering if I can slow down enough to run 7.00. I would think I need full throttle to cut a decent reaction time on the 4 tenths pro tree,I am foot braking. This Wednesday I am going to T&T and try to figure out if I can slow down enough to run 7.00. Is it possible to lower my shift point enough to run 7.00. I shift at 6800 rpm now and I have a 5800 rpm chip I am going to try. Does any body have any ideas? What were the conditions when you ran that BEST ??? if it was mineshaft type conditions I wouldn't use that as the gauge unless that is always the conditions . Me ... I would add weight, held securely of course, and run it out the back door. You can always remove a little weight to go faster if needed, and lift a tad if you are ahead just before the stripe.
[Re: JohnRR]
#1839647
06/02/15 12:31 PM
06/02/15 12:31 PM
MR_P_BODY
Ok , my best ET this year was a 6.21. I have been thinking about trying index racing at one of my local tracks. They have 6.0,7.0,8.0 and 9.0. I am too slow for 6.0 and wondering if I can slow down enough to run 7.00. I would think I need full throttle to cut a decent reaction time on the 4 tenths pro tree,I am foot braking. This Wednesday I am going to T&T and try to figure out if I can slow down enough to run 7.00. Is it possible to lower my shift point enough to run 7.00. I shift at 6800 rpm now and I have a 5800 rpm chip I am going to try. Does any body have any ideas? What were the conditions when you ran that BEST ??? if it was mineshaft type conditions I wouldn't use that as the gauge unless that is always the conditions . Me ... I would add weight, held securely of course, and run it out the back door. You can always remove a little weight to go faster if needed, and lift a tad if you are ahead just before the stripe. I did it my way because I was racing 2 classes and needed to change over in short order... weight was to much of a problem... I could change the throttle stop in less than a minute.. then it was change the rpm points.. this also allowed for the car to pick up if needed.. just hold the shift rpm a little higher... if you have weight and your slow.. your screwed(if during competition)
[Re: D-50]
#1839695
06/02/15 01:30 PM
06/02/15 01:30 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Lowering the shift points won't help much. I am familiar with some of the tracks you are talking about. It is a stupid idea to ask a 7.0 car to cut a .400 tree. A 7.0 car cuts a .500 tree, anything else is unnatural and will cost the competitor a lot to comply which doesn't help drag racing. You can slow down with timing.
2011 Drag Pak Challenger
[Re: D-50]
#1839800
06/02/15 03:39 PM
06/02/15 03:39 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I used to reduce timing 6° and shift 1500 Rpm lower to go 10.0 racing. I would also add some extra weight.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: dizuster]
#1839806
06/02/15 03:46 PM
06/02/15 03:46 PM
Posts: 360 Ohio
shorthorse
Ohio
Just move the throttle cable... Cheap and easy. Just what Dizuster said. I just started index racing in footbrake only classes. I'm racing with a lot of guys that have it down to a science (mostly by adding weights) and they are real good at it. I started by trying to adjust my shift points and actually did fairly well but not good enough against the hardcore index guys. At my last race the car ran two identical numbers during test & tune but it was running too slow. Then I realized I had been working on the top of my motor and when I reassembled it I forgot to adjust the throttle linkage. I adjusted the linkage correctly but after the race was over it hit me, adjust the throttle linkage to the index.
[Re: dizuster]
#1839997
06/02/15 08:53 PM
06/02/15 08:53 PM
D-50
North, Alabama
Just move the throttle cable... Cheap and easy. I realize moving the throttle cable would be the easiest way. I thought that I would need full throttle to help cut a better light since I am foot braking on a .400 tree. If everybody thinks that would not make any difference I will try it. I may try a combination of all the suggestions. A couple of years ago I broke the gears that I was running. I put a mini spool in a truck center section with 3.50 gears that I had so I could race the next weekend. At the next race after I did a burnout I pulled up to the line and forgot to put it back in first. I made that pass starting off in 3rd gear and ran the whole 1/8 in high gear. It still ran a 6.94 and I am running 30in. tall tires. I have 4.56's under it now. I think it is going to be hard to slow it down that much...
[Re: D-50]
#1839999
06/02/15 08:56 PM
06/02/15 08:56 PM
Posts: 791 Bama
Randy..
Bama
[Re: Randy..]
#1841140
06/04/15 02:19 AM
06/04/15 02:19 AM
D-50
North, Alabama
Well I went to T&T tonight and did not accomplish much. The air was bad and my 60 ft. times were bad. I made 2 passes with every thing the same as usual and ran a 6.36 and 6.37 at 108 mph with the normal 6800 chip in the shifter. I stuck a 7200 chip in to see what it would do. I have never shifted that high before. It ran a 6.33 shifting at 7200. Then I put a 5800 in and for some reason it did not shift into high and ran a 6.51 at 98 mph. It was turning a lot of RPM down toward the finish line in 2nd, I kept pulling the shifter back but it did not shift. So I believe it would have ran faster than the 6.51 if it would of shifted. So I am going to have to move the throttle or back timing down to slow down if it even will slow down that much to run 7.00.
[Re: dvw]
#1841721
06/04/15 09:34 PM
06/04/15 09:34 PM
D-50
North, Alabama
I have heard deep staging will slow your ET around a 10th. I am not sure it still is but deep staging use to be illegal. Back in the 90's when 6.0 and 7.0 first started nobody was running a transbrake and one guy would do a burnout past the starting line then back into the lights. That is as deep as you can get. That is when they banned deep staging.
