Lets play "What caused the carnage???"
#1838720
06/01/15 02:39 PM
06/01/15 02:39 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Well...I went to Kanawha Valley on Saturday because I just had to race this weekend. First I will say they are very nice people there. But....I noticed there were no dragsters...none...and when I spoke with an offical he said the won't run the track because the left lane is a bit bumpy. A bit??? Holy crap it almost shook my fillings out. So I ask around and the say the right is better. Well...I go buncing down the track again and in the traps a piston smacks the head. Pull a v/c and the valvetrain is not turning at all. So yesterday I pull the valley pan and see the piston pieces. Ok..chicken egg time. I haven't pulled the timing cover yet but I suspect I will find a broke chain...the cause...if I were a betting man would be the loading and un-loading down the track. Any opinions?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Lets play "What caused the carnage???"
[Re: Eric]
#1838751
06/01/15 03:15 PM
06/01/15 03:15 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
I would agree..Cam is broken, maybe from a rod or maybe a bad core. Had one do the same to me, bad core that is.
[Re: Eric]
#1838752
06/01/15 03:15 PM
06/01/15 03:15 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Where is the 'Kanawha Valley' you raced at???? I race at KV in West Virginia,,,,,it is not rough and there are plenty of dragsters there,,,,???
If you like drag racing, support your local track.
[Re: Eric]
#1838795
06/01/15 04:13 PM
06/01/15 04:13 PM
Eric
Pittsburgh PA
Still a solid Dave. Chapper...there wasn't a single dragster there?? and the official told me they won't run the left lane. Most of the faster door cars could'nt get down the track also. I'm just saying I've never had the car bounce like that before.
[Re: Eric]
#1838939
06/01/15 06:00 PM
06/01/15 06:00 PM
CHAPPER
Belpre,Ohio
You are talking about Kanawha Valley @ Winfield, West Virginia on Rt. 35.......I have one friend that has 2 dragsters that his sons drive that are there just about every weekend. They both run in the 5.0x most of the time and someother friends in the 4's. Lots of mid 5's door cars usually. I am setting out for awhile with a cracked block,,,or I would have been there. Sorry you had a bad trip/experience at my home track. Maybe you should have gone to Magnolia,,,closer anyway.
[Re: Eric]
#1838953
06/01/15 06:12 PM
06/01/15 06:12 PM
Eric
Pittsburgh PA
No worries Chapper...I like to try different tracks and they were very nice there.
[Re: Eric]
#1839084
06/01/15 07:46 PM
06/01/15 07:46 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
The cam is a possibility, my old 9 second '73 DartSport has a ton of passes on it over the years, the cam broke on the new owner last fall and it was the only thing that broke so it is possible. Hope you get it figured out Eric.
[Re: wyoming]
#1839322
06/01/15 11:40 PM
06/01/15 11:40 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I have a 541ci RB that I built for a friend break a cam last year. Broke right behind the dist gear, bent a lot of valves. Replaced the cam, timing chain set and all the valves, no other problems. Even the front cam bearing was good. The cam was only about 6 mo old, a Comp Cams solid lift 650/650. The machinist that I use said that he sees this in round track engines 4 or 5 times a season, rarely in drag racing.
Brian
[Re: Eric]
#1839464
06/02/15 01:59 AM
06/02/15 01:59 AM
Posts: 561 USA
B3RE
USA
Sorry to hear about the damage.
I'm thinking that since it happened in the traps, when you were at speed (shouldn't have been loading/unloading there), the motor got into sustained valve float, and took out the parts that got in the way.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Lets play "What caused the carnage???" UPDATE
[Re: 440Jim]
#1848356
06/13/15 10:46 PM
06/13/15 10:46 PM
Eric
Pittsburgh PA
Timing chain broke. I'm still thinking the loading and unloading killed it. Next time I'll know better and shut it down to race another day.
