Lets play "What caused the carnage???" #1838720
06/01/15 02:39 PM
06/01/15 02:39 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Well...I went to Kanawha Valley on Saturday because I just had to race this weekend. First I will say they are very nice people there. But....I noticed there were no dragsters...none...and when I spoke with an offical he said the won't run the track because the left lane is a bit bumpy. A bit??? Holy crap it almost shook my fillings out. So I ask around and the say the right is better. Well...I go buncing down the track again and in the traps a piston smacks the head. Pull a v/c and the valvetrain is not turning at all. So yesterday I pull the valley pan and see the piston pieces. Ok..chicken egg time. I haven't pulled the timing cover yet but I suspect I will find a broke chain...the cause...if I were a betting man would be the loading and un-loading down the track. Any opinions?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Lets play "What caused the carnage???" [Re: Eric] #1838736
06/01/15 03:02 PM
06/01/15 03:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm thinking you broke the cam near the front
wave
Re: Lets play "What caused the carnage???" [Re: Eric] #1838751
06/01/15 03:15 PM
06/01/15 03:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I would agree..Cam is broken, maybe from a rod or maybe a bad core. Had one do the same to me, bad core that is.
Re: Lets play "What caused the carnage???" [Re: Eric] #1838752
06/01/15 03:15 PM
06/01/15 03:15 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Where is the 'Kanawha Valley' you raced at???? I race at KV in West Virginia,,,,,it is not rough and there are plenty of dragsters there,,,,???
If you like drag racing, support your local track.
Re: Lets play "What caused the carnage???" [Re: CHAPPER] #1838760
06/01/15 03:26 PM
06/01/15 03:26 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Yep - it went boom - my guess - your exhaust valve was a little tight and decided to become one with the piston - Are you still running a solid tappet or did you upgrade to a Roller?? - either way it is not gonna be pretty when you take the head off.
Re: Lets play "What caused the carnage???" [Re: Eric] #1838795
06/01/15 04:13 PM
06/01/15 04:13 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Still a solid Dave. Chapper...there wasn't a single dragster there?? and the official told me they won't run the left lane. Most of the faster door cars could'nt get down the track also. I'm just saying I've never had the car bounce like that before.
Re: Lets play "What caused the carnage???" [Re: Eric] #1838939
06/01/15 06:00 PM
06/01/15 06:00 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
You are talking about Kanawha Valley @ Winfield, West Virginia on Rt. 35.......I have one friend that has 2 dragsters that his sons drive that are there just about every weekend. They both run in the 5.0x most of the time and someother friends in the 4's. Lots of mid 5's door cars usually. I am setting out for awhile with a cracked block,,,or I would have been there. Sorry you had a bad trip/experience at my home track. Maybe you should have gone to Magnolia,,,closer anyway.
Re: Lets play "What caused the carnage???" [Re: Eric] #1838953
06/01/15 06:12 PM
06/01/15 06:12 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
No worries Chapper...I like to try different tracks and they were very nice there.
Re: Lets play "What caused the carnage???" [Re: Eric] #1839054
06/01/15 07:26 PM
06/01/15 07:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that sucks Eric, I doubt very seriously the cam broke first. more than likely a rod took it out.
Re: Lets play "What caused the carnage???" [Re: Eric] #1839084
06/01/15 07:46 PM
06/01/15 07:46 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
The cam is a possibility, my old 9 second '73 DartSport has a ton of passes on it over the years, the cam broke on the new owner last fall and it was the only thing that broke so it is possible.
Hope you get it figured out Eric.
Re: Lets play "What caused the carnage???" [Re: Eric] #1839177
06/01/15 09:03 PM
06/01/15 09:03 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My wife broke the cam in her motor the 1st race of the year...piston came apart and made a mess of everything...literately, cam in 3 pieces, block cracked, etc.
Re: Lets play "What caused the carnage???" [Re: Eric] #1839232
06/01/15 09:57 PM
06/01/15 09:57 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Not a chicken or egg guess, but I don't believe you can break a timing chain because of the bumps, I've been meaning to get down to the track, but never heard it was real rough? I'd guess the cam is broken also, hopefully not sawed through by a rod.
Re: Lets play "What caused the carnage???" [Re: Eric] #1839308
06/01/15 11:29 PM
06/01/15 11:29 PM
Lehigh Acres, Florida
rickstershemi Offline
Sorry to hear Eric....hope it's not as bad as it sounds. But doubtful the track had anything to do with it ;(
Rickster
Re: Lets play "What caused the carnage???" [Re: wyoming] #1839322
06/01/15 11:40 PM
06/01/15 11:40 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I have a 541ci RB that I built for a friend break a cam last year. Broke right behind the dist gear, bent a lot of valves. Replaced the cam, timing chain set and all the valves, no other problems. Even the front cam bearing was good.
The cam was only about 6 mo old, a Comp Cams solid lift 650/650. The machinist that I use said that he sees this in round track engines 4 or 5 times a season, rarely in drag racing.
Brian
Re: Lets play "What caused the carnage???" [Re: Eric] #1839385
06/02/15 12:36 AM
06/02/15 12:36 AM
NC
barracuda man Offline
NC
don't feel bad Eric.I had a bme rod let go this weekend.took out the block and the oil pan.nice milodon pan.happened right at the finish line.I thought when a aluminum rod lets go it wouldn't hurt the block.Boy what a mess.order some h beams today for the new build.
Re: Lets play "What caused the carnage???" [Re: Eric] #1839464
06/02/15 01:59 AM
06/02/15 01:59 AM
USA
B3RE Offline
B3RE  Offline
USA
Sorry to hear about the damage.
I'm thinking that since it happened in the traps, when you were at speed (shouldn't have been loading/unloading there), the motor got into sustained valve float, and took out the parts that got in the way.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Lets play "What caused the carnage???" [Re: Eric] #1839568
06/02/15 10:37 AM
06/02/15 10:37 AM
NC
440Jim Offline
440Jim  Offline
NC
Ouch, sorry to hear that.
I have heard of a few Comp Cams solid cams (cast cores) break within a few months of new. Since you have the valley pan off, you should be able to see most of the cam to check if the front is broke. Or if the timing chain broke first and let the valves hit the pistons.
Re: Lets play "What caused the carnage???" UPDATE [Re: 440Jim] #1848356
06/13/15 10:46 PM
06/13/15 10:46 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Timing chain broke. I'm still thinking the loading and unloading killed it. Next time I'll know better and shut it down to race another day.
