Page 3 of 3 1 2 3
Re: Joss Engines 542ci Low Deck Build Thread [Re: Airwoofer] #1601326
01/14/15 07:16 PM
01/14/15 07:16 PM
Alberta Canada
StrokerAspen Offline OP
Alberta Canada
I am interested in hearing how you plan to run 14.2-1 CR on 94 pump swill with meth.
It doesn't come down to just the compression ratio, it's the complete engine design. I've seen aluminum headed engines that detonate on 94 with 11:1 compression. On the other hand, the Aspen in my signature is 13.3:1 with a cast iron head on it, and it runs 94 all day long with a meth kit for good measure.
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1837870
05/31/15 11:44 AM
05/31/15 11:44 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Hey Kenny, just wondering how this build ever turned out? I am guessing that the aluminum rods play a big part in letting stroke this big live in a stock block?
Re: Joss Engines 542ci Low Deck Build Thread [Re: mshred] #1837918
05/31/15 12:44 PM
05/31/15 12:44 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Just curious....Have you clearanced the bore notches completely in the block? Seems like you'd need a bigger 'scallop' taken out to clear a low deck with that much stroke and a fat shouldered Aluminum 6.535" Rod. Just curious if that's really all it took or you still have more to go. Is that a 2.200" journal or is it a 2.100 (350 sbc) rid journal?
WIZE
In Car:
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1837926
05/31/15 12:53 PM
05/31/15 12:53 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
cool build. but I'm interested to know how your aluminum Ritter block runs. I know you had it on the dyno and had some leaks but not sure if I ever seen any follow up post.any information would be a great help to those that have purchased one of those blocks
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1839731
06/02/15 02:17 PM
06/02/15 02:17 PM
Canada
RobR Offline
RobR  Offline
Canada
XL nice crank...that my go to crank..4.250 = 57 lbs..Tq comes in 800 rpm sooner.
Re: Joss Engines 542ci Low Deck Build Thread [Re: RobR] #1839751
06/02/15 02:38 PM
06/02/15 02:38 PM
Canada
RobR Offline
RobR  Offline
Canada
I did not go through the whole thread,I see you couldn't wait for Callies to turn out an XL crank for you...Still A Very Nice Crank you have there..!
Re: Joss Engines 542ci Low Deck Build Thread [Re: RobR] #1840649
06/03/15 05:10 PM
06/03/15 05:10 PM
Iceland
BadMoonRacer Offline
Iceland
Thanks for sharing info on a very interesting build up. I like your guts. Best of luck, and keep us posted.
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1885805
08/05/15 07:17 PM
08/05/15 07:17 PM
Alberta Canada
Alberta Canada
Hey guys, sorry for the WAY LATE update. I decided to start my own business and have been spread pretty thin and have not been on moparts in a long time. I figured I should look up this thread since Dad is getting close to having this thing on the dyno. It has been a long time coming, and it has been collecting dust while he has been in his busy season with customer's projects.
Hey WHITEDART, I will give an update on the aluminum Ritter block build soon as well. It has been a headache to say the least, but a challenge we still welcome. It is running, and the oil drain back issues have been addressed which as far as I know was the last to deal with.
Streetwize, the clearancing needed, as well as the rod journal (2.200") is shown on the previous page of posts.
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1886053
08/06/15 01:01 AM
08/06/15 01:01 AM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Not to hijack but Chuck at Best Machine has also been building a low deck wedge motor...565 ci...Details can be had on their website...
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1924230
10/02/15 03:40 PM
10/02/15 03:40 PM
Alberta Canada
Alberta Canada
A quick update! Been moving slower than planned, customer enginers are "getting in the way" hahaha! Here is some pictures of it ALMOST complete! With the retainers we are using, and the spring we needed, The T&D's would not clear. We had to go with the Harland Sharps, which required a different push rod. BUMMER. So once those are here, we will be putting the engine on the engine dyno for a break in and then into the car to tune on the chassis dyno.
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1924231
10/02/15 03:45 PM
10/02/15 03:45 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Nothing to see here! Just an unassuming 383 with a fancy intake! Looks good
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1958824
11/27/15 04:37 PM
11/27/15 04:37 PM
Alberta Canada
Alberta Canada
I will just leave these here...
Doing a little testing now, Haven't made a full pull yet, but it looks promising.For a little comparison, it has made 120bhp more than the 468ci W2 in my car on the pull we went to 6500rpm haha! We would like to make our own rocker spacers to get the rockers in a little more favourable location, but after that, I think we will be ready to really lean on it!
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1960409
11/30/15 08:13 PM
11/30/15 08:13 PM
Alberta Canada
Alberta Canada
Here is a couple pulls to 7000rpm. It was making 115 points @ 7000rpm. Sooooo, 115 x 7 = 805bhp uncorrected. We race at about 4000-5000ft typically. I look forward to getting it in the car and on the chassis dyno to do some tuning on it!!
https://youtu.be/NCbxaYC51B8
Thanks for watching!
-Kenny
Page 3 of 3 1 2 3
