Dynomax mufflers #1837633
05/31/15 12:06 AM
05/31/15 12:06 AM
NY
Beep Beep Offline OP
NY
Hi everyone,
I am currently running a 2 1/2" TTI Xpipe setup on a 550hp setup with superturbo mufflers. Are there any benefits of running the Ultra flows in 2 1/2". The car is for street only. Ultra flow makes 2 lengths. One is exactly the same length as my super turbo which is 20"s. The other is 14"s. Does it matter which length I choose?
Re: Dynomax mufflers [Re: Beep Beep] #1837658
05/31/15 12:33 AM
05/31/15 12:33 AM
RapidRobert Online content
RapidRobert  Online Content
are you after more free flowing to free up some HP which will be noisier or more restrictive to quiet your system some which generally costs some power? to ans your Q a longer muff will subject the gasses to more muffling which will be quieter assuming the longer muff will fit your vehicle. Just me I'd keep the Dynomax's (they're a good muff) and add some glasspacks alongside the rear leaf springs for addit'l quieting. with that plan make sure your choice of GP does not neck down where the end nipples are welded to the case
Re: Dynomax mufflers [Re: Beep Beep] #1837679
05/31/15 01:01 AM
05/31/15 01:01 AM
NY
NY
RapidRobert,
I was just curious if I switched to the Ultra Flo's would I be gaining any hp over the super turbo's? I figured with using 2 1/2" exhaust with that much hp, the straight through design of the Ultra Flo's should help with more flow? If I am going to gain a couple of hp then I would just stay with the super turbo's. If we are talking 10hp then I would switch to the Ultra Flo's.
Re: Dynomax mufflers [Re: Beep Beep] #1837694
05/31/15 01:30 AM
05/31/15 01:30 AM
a straight thru would gain some over a "regular" type with a center nipple and an offset nipple. Not sure how much. I ain't an ex engineer but If I was serious & wanting to experiment, what I'd do to start is take a pressure reading in front and in the rear of the current muffs at WOT. Just WAG I think you'd notice the noise increase but not a performance increase. My pref is a restricted (quiet) system with open cutouts right at the collectors. with the money in a third parties' hand I open em up & 10 seconds later its all over but the cryin & the money is (now) in my hands then I close the cutouts
Re: Dynomax mufflers [Re: Beep Beep] #1837707
05/31/15 01:56 AM
05/31/15 01:56 AM
NY
NY
LOL, you got to love the electric cut outs!
Re: Dynomax mufflers [Re: Beep Beep] #1837715
05/31/15 02:10 AM
05/31/15 02:10 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
I have had Ultra Flow Welded (oval, 20-inch case) mufflers on my 71 Charger (440) and '79 CJ5 (AMC 304 V8) for over 10 years. I'm using 3-inch exhaust with H-Pipes. They do flow well (they should, as they are essentially glass packs) but are a bit noisy for constant street use.
I tried adding Dnomax bullet mufflers to the Charger (so, 4 - mufflers on one car), but it didn't help much with the noise level. Ear plugs are helpful on the freeway, else your ears will ring. I keep a set handy in the glove compartment.
Then again, a 2 1/2 inch system, all the way to the rear bumper, may help / be acceptable.
Seat of the pants, they DO seem to improve performance, but I haven't had either on a Dyno to verify by how much. The exhaust note while winding out, sounds (somewhat) like a Pro Stock engine.
Re: Dynomax mufflers [Re: Beep Beep] #1837796
05/31/15 09:55 AM
05/31/15 09:55 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Your choice !
OEM..................................... ........................................ ...225
Gibson SuperFlow 788200.................................. ............311
TTS Bullet Cat Converter............................... ..................324
Flowmaster 40 series 42540................................... .......352
Flowmaster 50 Series.................................. ...................362
Flowmaster 40 series 43040................................... .......392
Dynomax Super Turbo................................... .................410
Flowmaster 62631................................... .......................435
Carsound Cat Converter............................... ..................436
FLP Cat Converter............................... ............................440
Edelbrock Victor 5535.................................... ..................562
Flowmaster 40 series 435409.................................. ........576
Edelbrock RPM series 5511.................................... ..........579
Flowmaster Delta Force Racing 54040-10........................634
Edelbrock 304 series 5560.................................... ...........640
Edelbrock Gen App 5505.................................... ..............708
Dynomax Race Magnum Welded 17216...........................711
Borla XR-1 40600................................... ..........................836
Borla XR-1 40615................................... ..........................854
Dynomax UltraFlow SS 17263................................... .......1000
Dynomax Race Magnum Welded 17218...........................1000
Borla XR-1 40575................................... ..........................1100
Dynomax UltraFlow............................... ...........................1133
Edelbrock Victor 5537.................................... ..................1400
Borla XR-1 40450................................... ..........................1400
Borla XR-1 40741................................... ..........................1450
Dynomax UltraFlow SS 17296, 17268..............................2200
Dynomax Race Magnum Welded 17220, 17224...............2200
Dynomax Race Magnum Welded 17225...........................2600
Re: Dynomax mufflers [Re: Beep Beep] #1837808
05/31/15 10:07 AM
05/31/15 10:07 AM
NY
NY
Thanks guys,
Dynomax ultraflo at 1133 and Dynomax super turbo at 410 cfm looks like a huge difference. It might be worth the change.
Re: Dynomax mufflers [Re: 62maxwgn] #1837823
05/31/15 10:32 AM
05/31/15 10:32 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Originally Posted By 62maxwgn
Your choice !
These are DECIBEL ratings?...........(joking)
Keep old mopars alive.
Re: Dynomax mufflers [Re: Beep Beep] #1837824
05/31/15 10:36 AM
05/31/15 10:36 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I have the 2.5" TTI X-pipe system and the Dynomax welded ultra-flos in the short case on my car, with straight cut tips that exit and inch past the bumper and it's pretty quiet in the car. Rolling on the freeway at 70 (3000 rpm), I can hear the tire noise (and they aren't loud tires) over the exhaust. Other than pretty much right at 2000 rpm, they are pretty quiet. Not bad at all for mufflers you can see through.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Dynomax mufflers [Re: Beep Beep] #1838031
05/31/15 03:16 PM
05/31/15 03:16 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Anyone know what the Hooker max flow mufflers are rated at ??
Nautilus Racing-
Re: Dynomax mufflers [Re: Beep Beep] #1838058
05/31/15 04:41 PM
05/31/15 04:41 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Seems like you are in a perfect position to do some track testing of each and reporting back
Re: Dynomax mufflers [Re: Beep Beep] #1838133
05/31/15 06:43 PM
05/31/15 06:43 PM
NY
NY
I think I may have to buy a set and try them out. I would think they will make more power than the Super Turbos. Thanks everyone.
Re: Dynomax mufflers [Re: Chris2581] #1838280
05/31/15 10:51 PM
05/31/15 10:51 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Chris 2342:
I have found the Hooker 2.5" Max Flows are at the same flow rating as 2.5" pipe, 521cfm! I love the sound of mine!
Re: Dynomax mufflers [Re: Beep Beep] #1838345
06/01/15 12:30 AM
06/01/15 12:30 AM
gregsdart Offline
gregsdart  Offline
For a sound reference, I put a pair of super turbos on my 318 Dart, with a 2 1/2 inch system and a cross over, and you can barely here it run. If they truly do flow 410 each, that would equal a zero loss at 364 hp, or 2 percent loss at 410 hp.
Vizards book shows 2.25 cfm per open pipe hp equals no loss, 2 cfm equals 2 percent, 1.75 cfm equals a 5 percent loss.
My next engine is going to be roughly 500 hp, so I am looking at a loss of about 8 percent, or 40 hp, but the car will be very quiet for what it is. The loss might even be less, as the mufflers are where the spare tire used to be, at the back of the car.
Re: Dynomax mufflers [Re: Beep Beep] #1839287
06/01/15 11:03 PM
06/01/15 11:03 PM
NY
NY
I went ahead and ordered the Ultra flo's today. I am thinking with my hp range the Super turbos have to be restricting it.
Re: Dynomax mufflers [Re: Beep Beep] #1839633
06/02/15 12:18 PM
06/02/15 12:18 PM
an8sec70cuda Offline
You will see a noticeable power increase after putting the Ultraflows on.
The Hooker Max Flows are almost the exact same style of muffler as the Dynomax Ultraflow and will perform the same.
The Hooker Aerochamber is a little quieter and more restrictive than the Ultraflow or Max Flow, but performs way better than the Super Turbo.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dynomax mufflers [Re: an8sec70cuda] #1839932
06/02/15 06:53 PM
06/02/15 06:53 PM
D_C Offline
D_C  Offline
Many years back (high school) when I heard the name "Turbo Mufflers", I thought they must have a Turbine Wheel inside that would spin to reduce noise, yet be less restrictive. Never tried cutting one open.
Of course, the name instead referred to mufflers used on Turbocharged Chevrolet Corvairs, designed to be less restrictive.
Also, what about "Muffler Bearings"?
Re: Dynomax mufflers [Re: Beep Beep] #1839991
06/02/15 08:49 PM
06/02/15 08:49 PM
NY
NY
That is what I am looking for more power! That is a nice muffler bearing. Lol
Re: Dynomax mufflers [Re: Beep Beep] #1840083
06/02/15 10:32 PM
06/02/15 10:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the Ultra-Flows in my 3" full exh system thats out to the back of the car and I use the X-pipe. I can say it is not as noisey as many cars out there when idleing or cruising. But when I nail it then it is alot louder. But I can listen to my radio when cruising along with no trouble. Ron
Here is a clip of it idleing and driving off at light throttle.
https://www.youtube.com/watch?v=bYIM2HLaOI4&feature=related
