Flexplate recertification #1836657
05/29/15 02:09 PM
05/29/15 02:09 PM
Beautiful Downtown Bahama, NC
tact1 Offline OP
tact1  Offline OP
Called B&M to have a flexplate sent back for re-certification. Been trying to get a response via e-mail by registering and they never sent me an e-mail link to complete registration. They also never responded to my request to start a customer service "ticket." I called them today and got a response from the phone rep. that said "We don't re-certify our flexplates." So I have to buy a new one? He said "Yes." That was about as poor customer service as I have found. I will never buy anything else from B&M. Question is, what do I buy? TCI? Or, does anyone ever check certification dates during tech inspection?
"Four out of three people have a problem with fractions"
Re: Flexplate recertification [Re: tact1] #1836662
05/29/15 02:12 PM
05/29/15 02:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
That is pretty much the same with everyone. No one recerts that I am aware of except Meziere and Reactor, both of those are north of $350. Some will send you a certificate good for some $$ of the NEXT one you buy. Just the way it is these days, built in income.
Re: Flexplate recertification [Re: tact1] #1836669
05/29/15 02:17 PM
05/29/15 02:17 PM
I've never seen (or heard of)a NHRA tech inspector crawl under any car to look at the dates on the SFI tags work Stock Mopar flexplates can and will crack when abused enough by a out of balanced motor but that isn't dangerous like the other brands with the ring gears on the flexplates that can fly apart and become shrapnel work shruggy
Re: Flexplate recertification [Re: Cab_Burge] #1836722
05/29/15 03:28 PM
05/29/15 03:28 PM
tact1 Offline OP
tact1  Offline OP
Looks like I will put it back on and run it some more. Thanks.
Re: Flexplate recertification [Re: tact1] #1836947
05/29/15 10:42 PM
05/29/15 10:42 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
JW will recert their Billet flexplate. They no longer recert "The Wheel". Naturally billet is more expensive.
Re: Flexplate recertification [Re: Blucuda413] #1837113
05/30/15 02:41 AM
05/30/15 02:41 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Same as Meziere and Reactor, thye recert billet pieces.
Re: Flexplate recertification [Re: tact1] #1837168
05/30/15 10:00 AM
05/30/15 10:00 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You couldn't see the tag on mine if you tried. If they were worried about the ring gear you would think they would certify Mopar converters. Oops did I say that? I better shut up before they do.
Doug
Re: Flexplate recertification [Re: dvw] #1837181
05/30/15 10:32 AM
05/30/15 10:32 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I have never ever had any tech ask about FP cert.if they did GOOD LUCK tryin to get a look at it. runaway
Re: Flexplate recertification [Re: bonefish] #1837256
05/30/15 01:03 PM
05/30/15 01:03 PM
Az
Crizila Offline
Crizila  Offline
Az
iagree but they do ask me about half the time. I got a spare cert sticker with my damper which I display. Other than my helmet ( which they check every time ), belts, damper, flex plate, fuel tank ground, batt shut-off, fuel line routing, wheel studs, locking trans stick, are hit and miss. I think the tech guys get together in the morning and decide what they are going to hit on for the day. shruggy
Fastest 300
