Removing #7 Spark Plug out of a B body Hemi with..... #1836944
05/29/15 10:34 PM
05/29/15 10:34 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
A power brake booster.
How the heck do you get the plug out. The booster is right in the way and no way can I get a extention or socket in there.
Any tricks to remove the spark plug and then get that flexible boot back on. It's a bear.
Re: Removing #7 Spark Plug out of a B body Hemi with..... [Re: Sammy] #1836951
05/29/15 10:46 PM
05/29/15 10:46 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
remove the master from the booster. don't disconnect the brake line just pull it away and secure it.
then remove the booster from the bracket.
now the plug is easy to get to.
perception is 90% of reality
Re: Removing #7 Spark Plug out of a B body Hemi with..... [Re: Sammy] #1837020
05/30/15 12:22 AM
05/30/15 12:22 AM
AndyF Offline
AndyF  Offline
Put late model B-body 11.75 inch disc brakes on there and then you can ditch the booster.
Re: Removing #7 Spark Plug out of a B body Hemi with..... [Re: Sammy] #1837117
05/30/15 02:58 AM
05/30/15 02:58 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You'll need to remove the 4 nuts (pictured below) on the backside of the booster, disconnect the linkage from the end of the booster rod, carefully "rotate" the booster off towards the drivers side, no need to disconnect the brake lines or master cylinder, just "relocate" the booster...this is the way the factory intended it to be done...
FYI...be sure to remove the compression washers from the new spark plugs you may be installing, they are not needed/nor used on the HEMI, if the plug your pulling already has compression washers on them, hopefully they didn't distort the plug tubes?...causing oil leaks into the tubes
Mike
Re: Removing #7 Spark Plug out of a B body Hemi with..... [Re: DAYCLONA] #1837162
05/30/15 09:38 AM
05/30/15 09:38 AM
moparx Online content
moparx  Online Content
not to hijack[ever notice when that is said, that is what occurs ? grin], but i have always wondered what, if any, pedal ratio is changed using that linkage arrangement ?
beer
