Re: Paint guys- I'm behind the eight ball
[Re: gdonovan]
#1836528
05/29/15 10:55 AM
05/29/15 10:55 AM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
Because of it's intended use, I don't think I would bother painting it. But, that's just me!
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: 19swinger70]
#1836535
05/29/15 11:09 AM
05/29/15 11:09 AM
Posts: 1,559 Michigan
Kiddart
Go with your plan of the summit paint. Don't roll paint on it. the last thing you want to be is the laughing stock of the autocross. if you have come this far take the extra step and do the paint your self. no matter how long its been it will look way better than a roller!!.
Good Luck
Thank you Kiddart
[Re: gdonovan]
#1836543
05/29/15 11:21 AM
05/29/15 11:21 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Epoxy primer is not intended to be block sanded. You can wet sand it with 400-600 wet to knock down any dust in it.
Your plan sounds pretty reasonable, and sounds like you have some previous experience. If I was doing a down and dirty paint job on that car, I would sand it down with 320 and a DA. You really need to ensure all the areas where the clear is worn or delaminated is removed back to a solid substrate. Fix any dents etc with plastic filler or glazing putty depending on depth, or your care level. You really need a 2k primer surface to cover any body work you do. Finish that out to 320 dry. At that point you can epoxy prime the entire car. If you go with black epoxy, you can run that as a satin finish itself. While not being a topcoat, it might save you some effort and cash for your timeline. If you want to finish with the hot rod black, you can shoot the epoxy and let it flash off then shoot the topcoat over it. Your choice since it will all be masked anyway.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: Kiddart]
#1836551
05/29/15 11:38 AM
05/29/15 11:38 AM
Posts: 1,584 MD
p d'ro
MD
Good Luck Google rustoleum or marine paint roll on. They can look awesome, but are labor intensive since paint is very dilute and requires multiple coats and sanding. The beauty is retouching is simple. I have seen some very good ones.
[Re: herkamer]
#1836559
05/29/15 11:48 AM
05/29/15 11:48 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Epoxy primer is not intended to be block sanded. See? Way out of practice and out of my depth but always game to try. You really need a 2k primer surface to cover any body work you do. Finish that out to 320 dry. At that point you can epoxy prime the entire car.
So sand, fix the one ding, 2k primer (the whole car or just that area?) sand again and then hit it with epoxy primer? I'm tempted to hit the car with gloss black but just asking for trouble.
"I think its got a hemi"
[Re: Mr.Yuck]
#1836574
05/29/15 12:02 PM
05/29/15 12:02 PM
gdonovan
Oakdale CT
Since it is a track car...(and I suggest you try ChumpCar) I'd just prep it as best you can and let Maacco paint it. They have complete paint jobs for $259. You cannot beat that. Not around here they don't. Walk in any shop like that around here and they are like sharks that won't do anything but the top of the line.
[Re: gdonovan]
#1836584
05/29/15 12:08 PM
05/29/15 12:08 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Since it is a track car...(and I suggest you try ChumpCar) I'd just prep it as best you can and let Maacco paint it. They have complete paint jobs for $259. You cannot beat that. Not around here they don't. Walk in any shop like that around here and they are like sharks that won't do anything but the top of the line. Even if you prep it? What's the top of the line run? $500? I should have my dad come help ya. He painted my brothers 79 5.0 a nice gloss black in our driveway. Car still shiny today 15 years later.
[Re: Mr.Yuck]
#1836588
05/29/15 12:16 PM
05/29/15 12:16 PM
gdonovan
Oakdale CT
This is CT brother, try $3000
[Re: gdonovan]
#1836596
05/29/15 12:29 PM
05/29/15 12:29 PM
Mr.Yuck
Brookeville, Md
This is CT brother, try $3000 WOW.. I thought here in Md. we had it bad. They routinely have adds for 1/2 price paint jobs starting at $259. For 3k I'd have a real Pro shoot my car. Just pull it out in the yard, sand all the clear coat off, Hit it with some primer, sand and shoot your Semi-gloss black and roll.
[Re: Mr.Yuck]
#1836598
05/29/15 12:34 PM
05/29/15 12:34 PM
gdonovan
Oakdale CT
Just pull it out in the yard, sand all the clear coat off, Hit it with some primer, sand and shoot your Semi-gloss black and roll. Actually planning on setting up plastic curtains in the big bay of the garage, that way minimize anything that gets in the paint.
[Re: gdonovan]
#1836602
05/29/15 12:49 PM
05/29/15 12:49 PM
gdonovan
Oakdale CT
Just got off the phone with a local shop, $3000-$5000 for the job even though the grill, bumper covers, door handles, mirrors, wing and trim are already off the car.
He did lower it down to $3000 after a few minutes on the phone.
[Re: gdonovan]
#1836626
05/29/15 01:21 PM
05/29/15 01:21 PM
dogdays
A "local shop" does not equal MAACO or Earl Scheib. You guys are talking about two entirely different kinds of paint jobs.
R.
Let your computer fingers do the walking.....for example,
MAACO 991 Dixwell Ave. Hamden, CT 06514 203-687-4710
[Re: dogdays]
#1836637
05/29/15 01:37 PM
05/29/15 01:37 PM
gdonovan
Oakdale CT
R.
$1500 quote which is better than $3000 but not $259 Not sure I'd feel comfortable with a shop an hour and a half out from home with a few unobtainable Shelby parts not to mention Dixwell Ave is a very bad section of town.
[Re: gdonovan]
#1836640
05/29/15 01:42 PM
05/29/15 01:42 PM
Posts: 4,848 Memphis
HemiRick
Memphis
quick and easy and cheap hit it w a fresh coat of clear and it will look like a million bucks.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: p d'ro]
#1836668
05/29/15 02:16 PM
05/29/15 02:16 PM
gdonovan
Oakdale CT
It's a mid 80s Chrysler to be used on the track. Rattle can, wet sand, done. Or scratch, spray, sand, done. Heck, forget the primer! Scuff and paint! I'd like it to be done at last half way right. The primer and paint from Summit isn't that expensive and a no rot car of this vintage is rather unusual.
[Re: gdonovan]
#1836724
05/29/15 03:29 PM
05/29/15 03:29 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
PlastiDip the car! I was going to do the roller thing on the Imperial but it's getting PlastiDip instead. It's far less work and expense. OnPoint Connections 780 Enfield St, Enfield CT 06082 860-253-0489 Mon-Fri 9-5, Sat By App only, Sunday Closed Services: Entire Vehicle, Rims, Emblems, Mirrors, Bumpers, Interior Panel, Subs/Amps, Grilles Onpointconnections.net Facebook.com/pages/OnPoint-Connections/212185322135691
