Trunk coating question #1835894
05/28/15 12:08 PM
05/28/15 12:08 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I have my 69 Dart at the paint shop and the question has arisen as to how I would like the trunk finished. I wasn't sure what to say so I thought I would ask here what would be best. Should the inside of the trunk, and particularly the inner sides of the quarter panels, be coated with something or just painted body color? It has been suggested to coat the inner quarters with bed liner but I'm not sure what to do. Before the car was stripped, there was some sort of coating on the inner quarters but I didn't know if that was applied at the factory or afterwards. If there should be coating, I'm not concerned about factory correct in appearance as the car is not original anyway so I will probably just go with the bedliner idea if there is supposed to be something in there. Also, when there a coating, would it have been left it's natural color or would body color paint have been applied over it?
Re: Trunk coating question [Re: 440mopar] #1835936
05/28/15 12:57 PM
05/28/15 12:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Originally - Sound deadner was applied before the quarters were welded on to the body, so paint over the top is normal.
Re: Trunk coating question [Re: Alaskan_TA] #1836228
05/28/15 09:33 PM
05/28/15 09:33 PM
IN
ahy Offline
ahy  Offline
IN
I painted mine body color and used a "premium" re-pop trunk mat from Y1. Looks fine, protects the trunk which I do use, easy to clean, not too expensive. Also easy to pull the mat and keep an eye on the metal and maintain, modify or touch it up as/if needed.
Re: Trunk coating question [Re: 440mopar] #1836410
05/29/15 01:46 AM
05/29/15 01:46 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
bed liner would be a good substitute for the orig sound deadener IHMO, then paint body color over it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Trunk coating question [Re: HemiRick] #1836571
05/29/15 12:01 PM
05/29/15 12:01 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
What areas would have been sprayed with the sound deadener? Was it just the sides of the quarter panels from the rear of the panel to somewhere over the wheelhouses or was it applied to the underside of the top of the quarters as well? Also, were the trunk floors ever coated?
