Re: Edelbrock 1411 lean issues on 440
[Re: chermik1999]
#1835224
05/27/15 01:10 PM
05/27/15 01:10 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Well could but still pings. That has to be dealt with as well.
So you wouldn't be worried with all that has gone on with this? Last week it punished well. Great throttle response, even with a one ledger 2.76, she smoked that one time well..lol. Now seems loss of power. But it did and still smells rich..too much. So I have to deal with that.. That's what started this
....it's not got lisc plates as I need an out of province inspection first. Can drive to the gas station, but I'll get some jerry cans of premium in today. See if the pinging backs down..
do not hook up the vac advance. It could be pinging because it's advancing up to 50*
[Re: chermik1999]
#1835395
05/27/15 04:40 PM
05/27/15 04:40 PM
Posts: 1,584 MD
p d'ro
MD
yuup...tried all areas. Is manual brakes, so no poster to worry about. Plus im getting 10-12 hg vacuum, so that's pretty normal. But spec sheet form year One said 14 at 800 rpm. But that could what they all said without checking the actual motor....lol I have a relative stock 440 with a mild XE262 Comp Cam, 915 heads, all cylinders at 160 and one down to 125 and it still pulls 20 hg vacuum. 10-12 with a bouncy needle seems telling, as do the relative low compression readings. Hopefully the leakdown reveals something easy. Unfortunately mine did not! Silver spring would get you the most gas early.. Maybe the .065 x .037 jet would do? Solve compression issue first.
[Re: Mr.Yuck]
#1835858
05/28/15 10:47 AM
05/28/15 10:47 AM
Posts: 61 Alberta, Canada
chermik1999
Alberta, Canada
do you still have the old carter 625? If it were me I'd pick up a Holley 750DP or HP. But that's me. Yuup I do, but it's real old. I would think it's too lean according to my AFR readings. But I could try it. This 750 was new on the crate motor I bought for the 72 Charger 3 years ago. We had issues right when we started that one up. So bought a 670 Avenger, and ran nice. It's a 475 HP build and higher compression. So I should have clued in putting it on my 440. Tis why I was thinking the QFT 750. Can jet down after if needed. But hard to go up. And that's what I was thinking????
[Re: chermik1999]
#1836103
05/28/15 05:40 PM
05/28/15 05:40 PM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
Is 12% really that bad? Considering the constant air pressure is bleeding past piston rings and maybe valves, is not how the engine actually operates, I think you real loss number is less than that when combustion is measured in tenths and hundredths of a second?
What were your other cylinder leakdown numbers?
2008 Challenger SRT8 1940 Chrysler Royal coupe
[Re: shaker340]
#1836157
05/28/15 07:16 PM
05/28/15 07:16 PM
chermik1999
Alberta, Canada
What were your other cylinder leakdown numbers? Well only checked the bad one. Guess I should. But an update is its not the rings. I just have had it off a bit from TDC. The sure is actually coming out the exhaust. Hear it like a tire leak...lol. This 440 has the oil filler on top #1&2 so you hear the air passing by making it sound like the crankcase. But it got worse after I did a wet test again. Now it's reading 45psi with 90psi feeding. So that exhaust valve has to be deal with. Makes more sense now with my carb sir problems I would say?
[Re: Supercuda]
#1836253
05/28/15 10:11 PM
05/28/15 10:11 PM
chermik1999
Alberta, Canada
OK...here's one plug as they all look the same. I just changed them for NGK short as these seemed to be very long. ????
You got a lot of problems if that plug is indicative of all 8. TOO RICH, your afr reading is plain wrong, period. Find somewhere else to take it, the tail pipe is not cutting it. Too long, if that much of the plug is exposed inside the combustion chamber you have issues. I suspect your timing problems are self induced as well. Supercuda...I owe you an apology. Wow...do I feel stupid. I finally welded in a bung. Being in the high side of the 750 even having that throttle shift issue, I'm at 12.5 at idle. A 15:1 diff from tailpipe. And innovate said it's fine? So accept my apology.... I did buy the QFT slayer 750 anyway. So I'll play with this eddy 750 for the experience, but think I'll change it. So now to deal with my valve issue according to the leakdown and finally get this on the road.
[Re: chermik1999]
#1836296
05/28/15 11:09 PM
05/28/15 11:09 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I appreciate it, just trying to help. Benn following along. Hope you get it sorted out, BTW, the jets and rods from your Edelbrock will work in a Carter too. You might have to swap rod covers if they are different though.
[Re: Supercuda]
#1836344
05/29/15 12:19 AM
05/29/15 12:19 AM
chermik1999
Alberta, Canada
I appreciate it, just trying to help. Benn following along. Hope you get it sorted out, BTW, the jets and rods from your Edelbrock will work in a Carter too. You might have to swap rod covers if they are different though. And I appreciate it..Well I've got this 1411 jetted down a bit and now my AFR is correct, I have to go down more. So I'm worried that the QFT 750 might be too much.ill take it for a spin and see what the other readings are then tweak some more. Thanks...mike
