'71-4 B body bucket seats- what are you using?
#1834603
05/26/15 03:44 PM
05/26/15 03:44 PM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
Son has finally agreed to sacrifice a few pounds for some more comfortable seats and get rid of the plastic race buckets. Since it's not a restoration and stock buckets are so expensive, I figure some comfortable aftermarket buckets or maybe another American manufacturer. SIL and I rented a '15 Mustang 'vert to drive from PCB to Pensacola NAS- I couldn't believe how comfortable they were. (Challengers were not available anywhere near PCB. ) So what are you using? Pics would be nice as well as mounting hints. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: '71-4 B body bucket seats- what are you using?
[Re: Alaskan_TA]
#1834628
05/26/15 04:15 PM
05/26/15 04:15 PM
I_bleed_MOPAR
Buford, GA
Guess the folks down here don't know that about the '72-4 buckets. Anything you find seems to command a premium, even if it's just a rusty frame. I figured if I had to buy junk frames and then spend more on foam and covers, I might as well go aftermarket. P.S. Guess you still aren't doing PMs (I tried). If you want to send me some info on what you have, I would appreciate it. Bolt-ins would be nice. Tim
[Re: I_bleed_MOPAR]
#1834816
05/26/15 08:43 PM
05/26/15 08:43 PM
Posts: 350 Houston
it's Bob
Houston
The Cordoba/Charger/B-Fury & Monaco/Coronet buckets will also work...but they will be 1970s era comfortable. Later model mini-vans and K-cars will up the selection and might not be to bad of a fit. Measure your track width and then go to the local yard and see what is close and if you like it.
[Re: it's Bob]
#1835034
05/27/15 02:18 AM
05/27/15 02:18 AM
Posts: 164 Alberta.......
silvercloud
Alberta.......
If I remember right there was a guy over on the '71-'74 Charger board that installed 300M seats in his car? I can't remember what he had to do to make them fit but they looked good.
Jason
An '06 3500 QC 4x4 Laramie CTD with a 6.7 named "Frankentruck", an '80 W200 CC 440/435 yard truck, a Dakota, a Hemi Ram, and a bunch of projects....still working on resurrecting my '74 Charger after a 25 year hiatus for a "quick paint job"! Now a '78 D150 shortbox factory 440 to keep me occupied.
[Re: silvercloud]
#1835393
05/27/15 04:37 PM
05/27/15 04:37 PM
I_bleed_MOPAR
Buford, GA
Jason Didn't even know that board was around. Just signed up so I can look around for new info on 3rd gens. Never too old to learn. Thanks. Thanks to Barry (Alaskan TA) also. He's checking to see what he has squirreled away. Tim
[Re: I_bleed_MOPAR]
#1835735
05/28/15 01:25 AM
05/28/15 01:25 AM
silvercloud
Alberta.......
I haven't been on it for quite a while but I found lots of good 3rd gen tech stuff on there. Glad to be of assistance.
Jason
[Re: silvercloud]
#1835869
05/28/15 11:01 AM
05/28/15 11:01 AM
I_bleed_MOPAR
Buford, GA
Called my son last night about some seats Alaskan TA has and he reminded me the Charger has 5 pt. harnesses in it that he wants to keep. I guess we'll go aftermarket so time to start shopping. Thanks for the help (especially you, Barry). Tim
