Re: 1969 D100 How to stop massive wheel hop?
[Re: mopargreg]
#1831238
05/21/15 12:35 AM
05/21/15 12:35 AM
Posts: 15,487 Florida
scratchnfotraction
I have my 88 440 truck lowered & tubed axle on top of spring with no wheel hop. with the axle under spring it had wheel hop very bad.
on my stepside with NV4500 5 speed, I made some traction bars that went from plate on top of spring under u-bolts to the front spring hanger.
I drilled a hole in the front spring mount, then weld a bolt on a tube/rod for a bayonet style hook up with some shock rubber/washers.
did this on my 4x4 also, tucks the traction bars up out of the way on a axle under spring chassis.
[Re: scratchnfotraction]
#1831246
05/21/15 12:50 AM
05/21/15 12:50 AM
scratchnfotraction
I also flip the shackle and flopped the axle on top of the spring.
used an A-body 8 3/4 to tuck 12 rims in the fenders = do the same on the 69 truck.
then used a set of A-body SSM liftbars. they replace the lower shock plate with a square plate welded to a traction bar that clamps to the front segment of the springs, use shims to pre-load axle for launch/hook up.
I removed a leaf or 2 from a set of truck springs for them, they lift the back of the truck 3-4 inches and really plant the tires..you need to dial in the shocks so the don't bottom/extend out.
#1831250
05/21/15 12:53 AM
05/21/15 12:53 AM
scratchnfotraction
ssm lift bars work great with no wheel hop. but they WILL hop in reverse. DAMHIK!
