1969 D100 How to stop massive wheel hop? #1831221
05/21/15 12:11 AM
05/21/15 12:11 AM
Tampa Bay,Fl.
mopargreg Offline OP
Tampa Bay,Fl.
Hey guys, my 69 D100 shorty has massive wheel hop, now remember I have yanked leaves from the springs to lower it a little and the axle on these trucks sits under the leaf. Have any of you found a traction/ladder bar set up that will help with this spring wrap up and is not a whole fabrication job? Any advice or cures would be great....
Re: 1969 D100 How to stop massive wheel hop? [Re: mopargreg] #1831238
05/21/15 12:35 AM
05/21/15 12:35 AM
scratchnfotraction Offline
I have my 88 440 truck lowered & tubed axle on top of spring with no wheel hop. with the axle under spring it had wheel hop very bad.
on my stepside with NV4500 5 speed, I made some traction bars that went from plate on top of spring under u-bolts to the front spring hanger.
I drilled a hole in the front spring mount, then weld a bolt on a tube/rod for a bayonet style hook up with some shock rubber/washers.
did this on my 4x4 also, tucks the traction bars up out of the way on a axle under spring chassis.
Re: 1969 D100 How to stop massive wheel hop? [Re: scratchnfotraction] #1831242
05/21/15 12:38 AM
05/21/15 12:38 AM
like this when done. well maybe a little better craftsmanship just for looks. they work well though.
Re: 1969 D100 How to stop massive wheel hop? [Re: scratchnfotraction] #1831246
05/21/15 12:50 AM
05/21/15 12:50 AM
I also flip the shackle and flopped the axle on top of the spring.
used an A-body 8 3/4 to tuck 12 rims in the fenders = do the same on the 69 truck.
then used a set of A-body SSM liftbars. they replace the lower shock plate with a square plate welded to a traction bar that clamps to the front segment of the springs, use shims to pre-load axle for launch/hook up.
I removed a leaf or 2 from a set of truck springs for them, they lift the back of the truck 3-4 inches and really plant the tires..you need to dial in the shocks so the don't bottom/extend out.
Re: 1969 D100 How to stop massive wheel hop? [Re: scratchnfotraction] #1831250
05/21/15 12:53 AM
05/21/15 12:53 AM
ssm lift bars work great with no wheel hop. but they WILL hop in reverse. DAMHIK!
Re: 1969 D100 How to stop massive wheel hop? [Re: mopargreg] #1832357
05/22/15 06:14 PM
05/22/15 06:14 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 1969 D100 How to stop massive wheel hop? [Re: mopargreg] #1832549
05/22/15 11:45 PM
05/22/15 11:45 PM
Tampa Bay,Fl.
Tampa Bay,Fl.
Hey Wyle E, nice video, thanks for the link..... Hey Scratchn, check these out, think I'm gonna give them a try, (Tuff Country #30695) traction bars....Look a lot like what you built, can get the kit for $130.00, sounds reasonable to me.....
Re: 1969 D100 How to stop massive wheel hop? [Re: mopargreg] #1832737
05/23/15 11:17 AM
05/23/15 11:17 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Here is how it was done from the factory. The part came from an Imperial.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 1969 D100 How to stop massive wheel hop? [Re: Soopernaut] #1834924
05/26/15 11:11 PM
05/26/15 11:11 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
I have a wheel hop issue with my truck and have been thinking about making something like traction bars.
