Disc brakes on 8.75 #1832556
05/22/15 11:52 PM
05/22/15 11:52 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Looking to add discs on my Cuda with 8.75 rear. I hear I need to change axles to make this happen??
Re: Disc brakes on 8.75 [Re: Dr Dave] #1832570
05/23/15 12:06 AM
05/23/15 12:06 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Buy disc brakes for a 8 3/4 then.
Re: Disc brakes on 8.75 [Re: Dr Dave] #1832589
05/23/15 12:31 AM
05/23/15 12:31 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
No, you just need to decide whether you desire to go with Green Bearings and eliminate the bearing adjuster, or choose a kit that retains the tapered factory bearings and adjuster, a variety of kits are on the market, each has it's pro/cons...Dr Diff (Moparts Member) has several offerings and a more personal service
Personally I use SSBC disc components on 8 3/4 or Dana 60 applications along with Green Bearings, but I re/machine/replace some components to tailor my applications
Re: Disc brakes on 8.75 [Re: Dr Dave] #1832598
05/23/15 12:47 AM
05/23/15 12:47 AM
AndyF Offline
AndyF  Offline
Hi Dave,
Contact Cass at www.doctordiff.com and he'll set you up with what you need.
Re: Disc brakes on 8.75 [Re: AndyF] #1832823
05/23/15 02:37 PM
05/23/15 02:37 PM
IN
ahy Offline
ahy  Offline
IN
Rear discs are available to work with both taper and Green bearings though not all kits will work with taper. The link shows a Dr Diff kit installed with taper bearings. The axles usually need lengthened a little bit to account for the thicker caliper mount plate. I lengthened by welding a thick hardened washer on the end of each axle and then removing material to get the length right so they contact the thrust button and allow adjustment of end play.
https://board.moparts.org/ubbthreads/ubbt...tml#Post1829736
Re: Disc brakes on 8.75 [Re: Car Nut] #1832867
05/23/15 04:51 PM
05/23/15 04:51 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Why got to be a smart a$$ about it?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Disc brakes on 8.75 [Re: ahy] #1832878
05/23/15 05:14 PM
05/23/15 05:14 PM
AndyF Offline
AndyF  Offline
You had to weld washers to the end of the axles? That is odd, I've never had to do that. The DoctorDiff kits I've worked with are bolt on. The caliper bracket is the same thickness as the backing plate so it all bolts right on.
Re: Disc brakes on 8.75 [Re: Dr Dave] #1832895
05/23/15 06:03 PM
05/23/15 06:03 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Because OEM Mopar axles came with an adjuster on one side only, L and R axle flange stand-out is inconsistent. In other words, one rotor often requires a stack of shims while the other side doesn't have any room for adjustment.
You can install bearing adjusters on both sides, but the easiest solution is to weld/face a washer to the splined end of the axle to center the caliper over the rotor.
Of course, Green bearings always work without modification because the design equalizes L and R axle flange stand out.
Re: Disc brakes on 8.75 [Re: toplescuda] #1832896
05/23/15 06:16 PM
05/23/15 06:16 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
I suggested buying a disc brake kit for a 8 3/4, doesn't matter if it's an a body, b body, e body, etc. This wasn't meant to sound like a smart a$$ statement.
OP, When buying rear disc brake kits, you want to buy for the type of axle and wheels. Dr. Diff is where I bought my parts. There's https://scarebird.com/index.php?route=product/category&path=64 where you buy the brackets and source the rotors and calibers through local parts stores. I would also make sure that the kit/parts fits your wheels.
