Looking to add discs on my Cuda with 8.75 rear. I hear I need to change axles to make this happen??
No, you just need to decide whether you desire to go with Green Bearings and eliminate the bearing adjuster, or choose a kit that retains the tapered factory bearings and adjuster, a variety of kits are on the market, each has it's pro/cons...Dr Diff (Moparts Member) has several offerings and a more personal service
Personally I use SSBC disc components on 8 3/4 or Dana 60 applications along with Green Bearings, but I re/machine/replace some components to tailor my applications
