Re: How to increase torque [Re: Cab_Burge] #1831177
05/20/15 11:19 PM
05/20/15 11:19 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Originally Posted By Cab_Burge
Originally Posted By Wedgeman
The cam is installed at 106* ICL
Average 60ft is 1.32, 6.42 sec 1/8 mile, no mph....
I was thinking of a smaller carb for ET's......
Yes I want quicker acceleration !!!!!!!
That 60 ft. times is outstanding up bow I know some very successful NHRA SB Mopar stocker racers that would kill for those 60s shruggy The 1/8 miles times don't seem to jive with those 60. ft times to me workHow about some of the other SB racers on here, how does his 60 ft compare to yours? shruggy I'm thinking that the motor is running out of fuel in the upper gears, maybe not work
My 60ft is usually 1.33-1.34 with 4.56 gears and 30 in. tall drag radials.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: How to increase torque [Re: Wedgeman] #1831219
05/21/15 12:08 AM
05/21/15 12:08 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd advance the cam to 103 or 104. The headers may be holding it back on the top end. My 408 was 10.9-1, ported Edelbrocks, 260/264, .628/.633 flat solid, 1 7/8" Hedman headers. In street trim on pump 93 went 1.40, 6.70. In race trim it went 1.38, 6.57 on pump 93 at 3260#.
Re: How to increase torque [Re: Wedgeman] #1831391
05/21/15 12:41 PM
05/21/15 12:41 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Maybe it's here somewhere and I'm not seeing it but, what is the lobe center on your cam?
Re: How to increase torque [Re: Wedgeman] #1831662
05/21/15 07:49 PM
05/21/15 07:49 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
106*
Re: How to increase torque [Re: Wedgeman] #1831690
05/21/15 08:26 PM
05/21/15 08:26 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Add more gear. 10% gear is 10% torque. It already looks like it runs to it's potential.
Doug
Re: How to increase torque [Re: Wedgeman] #1831777
05/21/15 10:37 PM
05/21/15 10:37 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What's the stall?
Re: How to increase torque [Re: Wedgeman] #1831790
05/21/15 10:50 PM
05/21/15 10:50 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
THE STALL IS A 4500
Re: How to increase torque [Re: Wedgeman] #1831798
05/21/15 10:58 PM
05/21/15 10:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nice running combo !
Re: How to increase torque [Re: Wedgeman] #1831820
05/21/15 11:20 PM
05/21/15 11:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
THE STALL IS A 4500
I would advance the cam.. increase the stall and change
the gear... that will pretty give you all of the torque
you can find... if thats a 108 cam I would think of 102
or less... check the clearance
wave
Re: How to increase torque [Re: FastmOp] #1831824
05/21/15 11:24 PM
05/21/15 11:24 PM
montreal, quebec,canada
7e5dartsport Offline
salut wedgeman! the cheapest way to add torque is to lengthen collector extensions. also, no carb spacer or a thinner one could help if it hasnt been tryed before. let us know of the results.
fully legal sounds the same as full illegal...
Re: How to increase torque [Re: Wedgeman] #1831917
05/22/15 01:15 AM
05/22/15 01:15 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Remove 408 and install 605.....
Re: How to increase torque [Re: Wedgeman] #1831986
05/22/15 08:59 AM
05/22/15 08:59 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Go .004" tighter, then .004" looser from std' lash setting to see if the motor responds.
Might want a larger or smaller cam profile.
Re: How to increase torque [Re: LSP] #1832465
05/22/15 09:21 PM
05/22/15 09:21 PM
if you use an exhaust system, you could use cut-outs right after the headers. hooker and hedman make them among others. even electrical units are available.
Re: How to increase torque [Re: Wedgeman] #1832920
05/23/15 07:13 PM
05/23/15 07:13 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I have cut out...unfortunatly my et' wasn't better.........
Tu vas a st-eustache des fois ?
Re: How to increase torque [Re: Wedgeman] #1832926
05/23/15 07:28 PM
05/23/15 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your collector is in the 16"-18" range from
the end of the pri thats all you want
wave
Re: How to increase torque [Re: MR_P_BODY] #1832933
05/23/15 07:36 PM
05/23/15 07:36 PM
P
Porter67 Offline
Porter67  Offline
P
Id have to say gears or more compression as well. I recently went from the stroker norm of flat top zero deck slugs to the off the shelf wiseco 8cc domed and it made a world of difference in only the pistons were changed, rebalance.
Re: How to increase torque [Re: Porter67] #1832939
05/23/15 07:56 PM
05/23/15 07:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I did put a post up that if you changed any or all
would change the torque.. but advancing the cam is one
of the least costly ones
wave
Re: How to increase torque [Re: Wedgeman] #1833030
05/24/15 12:02 AM
05/24/15 12:02 AM
hi wedgeman. try adding a length of tube on the open end of the cutouts. that is what im doing on my street car when i go racing. i open the caps on the cutouts and add a collector each side. it is well worth it. i never raced at st-eustache but i have been there several times in the past wrenching for a friend of mine who was racing on the road course. i personnaly go to napierville dragway once or twice a year when i want to go racing. as we speak, i am rebuilding the differential i broke last fall. i just finished setting-it up this afternoon.
