E-body rallye tach repair #1828930
05/18/15 01:19 AM
05/18/15 01:19 AM
SoCal
droptail Offline OP
droptail  Offline OP
SoCal
Hi,
Has anyone repaired the 1970 rallye tach that came in the E-body, and could you perhaps say what component failed or was replaced?
' '70 Cuda convt - 383 bored/ported, Hemi cam, Rhoads, rollers, Mellings, MSD, 750 DP, LT dual 3", lowered, snubber, police chuck, discs, springs, sway bars, Transgo, posi, shaker, aluminum 17" rallyes w/275-285/40 EXTREMECONTACT SPORT, leather...
Re: E-body rallye tach repair [Re: droptail] #1829118
05/18/15 01:06 PM
05/18/15 01:06 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
There are a couple of large wattage resistors that fail after one of the transistors shorts out. I have never found a schematic for the board. I just replaced the innards with the RT Engineering board. Greg the designer says it is much more accurate and I have to agree. I have a Megasquirt board running on my car and its digital tach indicator is very close to the indication on my in dash factory tach with the new board.
Here is a write up on the install:
http://rt-eng.com/rte/images/8/8e/RealTimeEngTach_MoparActionApril20005.pdf
Craig
Re: E-body rallye tach repair [Re: droptail] #1831464
05/21/15 02:43 PM
05/21/15 02:43 PM
SoCal
droptail Offline OP
droptail  Offline OP
SoCal
Thanks Craig, I will give RT a call, and go through my OE PCB when I have time.
Re: E-body rallye tach repair [Re: droptail] #1831527
05/21/15 04:09 PM
05/21/15 04:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If you want someone else to mess with it, Shannon at www.redlinegaugeworks.com is local just in Santa Clarita.
Re: E-body rallye tach repair [Re: droptail] #1831540
05/21/15 04:33 PM
05/21/15 04:33 PM
NE Ohio
8
82firebird Offline
82firebird  Offline
NE Ohio
+1 For Redline Gauge works.
