Mopar Mini Starter with Blowshield
#1831341
05/21/15 10:52 AM
05/21/15 10:52 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I am using a Hayes blow shield with a 143 tooth Flywheel. Do you guys think the mopar mini starter Will work or should I use a factory starter. Also, should it be mounted On the inside diameter or outside where the little Tab was that got knocked out. It's a 10.5 compression Engine. Thanks
RS23L7 4-Speed
Re: Mopar Mini Starter with Blowshield
[Re: Mopar_Mike]
#1831715
05/21/15 09:08 PM
05/21/15 09:08 PM
Posts: 52 Texas
shart70rt
Texas
I ended up having to get a RobbMC starter. I am using 2" TTI headers, and they say it is the only starter that will work. Did not recognize this pre install, and switched to the RobbMC after fighting to get a Mopar mini-starter to work.
Stephen
70 Go Mango Charger RT White Vinyl Top 18 Spline 4 speed Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing 505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
[Re: SSAAHemiFan]
#1831994
05/22/15 09:16 AM
05/22/15 09:16 AM
Mopar_Mike
Danville, NH
Thanks. When you say "MP Starter" do you mean the mini starter or do you mean the factory/original bigger starter?
RS23L7 4-Speed
[Re: Mopar_Mike]
#1832262
05/22/15 03:43 PM
05/22/15 03:43 PM
Posts: 2,431 USA
SSAAHemiFan
USA
Thanks. When you say "MP Starter" do you mean the mini starter or do you mean the factory/original bigger starter? Ive used both = B-body has a factory starter the a-body has the mp mini starter - locations would be the same regardless of which starter you use.
[Re: Mopar_Mike]
#1832822
05/23/15 02:37 PM
05/23/15 02:37 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I run a Dodge Durango 360 mini starter in my 440.2 inch headers and scatter shield.Its been in at least 15 years and no problems.Reman fro Advance.Rocky
Chrysler Firepower
