440 pushrods #1829775
05/19/15 12:57 AM
05/19/15 12:57 AM
grande prairie , ab , canada
68notch Offline OP
68notch  Offline OP
I took edlebrock heads off my 400 and put them on my 440 , can anyone tell me what length of pushrods I need ? I tried comp 7442 9.030" and they are too long , I have adjustable rockers too , thank you
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
Re: 440 pushrods [Re: 68notch] #1829785
05/19/15 01:12 AM
05/19/15 01:12 AM
IN
ahy Offline
ahy  Offline
IN
Sounds like the length you have is in the ballpark of "Stock". if heads or block are milled or thinner head gasket would be too long however. Best approach is to use a checker pushrod to get actual length needed then order from somebody like Smith Brothers or order to length Comp. Or if possible, determine how much "too long" the current ones are and order accordingly.
http://www.manciniracing.com/cocamapu.html
Re: 440 pushrods [Re: 68notch] #1829804
05/19/15 01:58 AM
05/19/15 01:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You really need to use an adjustable checking pushrod and get the correct length pushrods. Not sure which rocker arms you have, but the ones that oil the pushrod through the adjuster have a very limited amount of adjustment, usually from all the way up to two turns down where you would set the adjuster one turn down and adjust the checking pushrod for the proper lash or pre-load (if hydraulic.) The rockers that oil the pushrod with a hole to the edge of the adjuster may be a bit more forgiving in adjustment range?
Re: 440 pushrods [Re: 451Mopar] #1829810
05/19/15 02:15 AM
05/19/15 02:15 AM
68notch Offline OP
68notch  Offline OP
ok il grab a checking pushrod , I was hoping there was a generic one , thanks guys
Re: 440 pushrods [Re: 68notch] #1829843
05/19/15 04:26 AM
05/19/15 04:26 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
From the Edelbrock Cylinder Head Installation Manual,
Pushrods compatible with adjustable rocker arm assembly stock length
440 c.i.d.- 9.125” hydraulic flat tappet, 9.250” solid flat tappet
http://www.edelbrock.com/automotive/misc/tech-center/install/6000/60189.pdf
So, if you are having length issues, adjustable length check pushrod may be required to sort things out.
On my 440, I was able to use Factory HD Stamped Steel Rockers. Not Ideal, but cheap and they worked.
When I mounted the rocker arms/shafts, torqued them to spec, fired it up, there was a problem. The lifters hadn't pumped up. Had to loosen the shafts, run the engine a bit, then re torque to spec. That was 12-years ago, the installation that is.
Re: 440 pushrods [Re: 68notch] #1829931
05/19/15 12:03 PM
05/19/15 12:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran Crane 3/8s on my 440 for years and no problems.With the solid cam I had to swap to longer ones with the aluminum heads and adj rods.The hydraulics used the same rockers.Rocky
Chrysler Firepower
