Re: Richard Ehrenberg Master Cylinder
[Re: 1fastrunner]
#182960
01/03/09 09:01 PM
01/03/09 09:01 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
A front drum brake master cylinder will not work with a disk brake conversion. That master cylinder should work as will several others. Provided its for a RWD disk brake equipped mopar car with manual brakes made from '73-on it should work well. The old standby could always be one for a '73-'74 Charger/Road Runner with manual brakes.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: 1fastrunner]
#182961
01/03/09 09:05 PM
01/03/09 09:05 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Does your master have two bolts or four holding it to the firewall?
I have one of Eberg masters on my 65 Coronet and it originally had four bolts holding the master to the firewall, so I needed an adaptor.
Youll need a new proportioning valve when you go to disc brakes, as 4 wheel drums doesnt use one. Adjustable prop. valves are inexpensive.
[Re: DoctorDiff]
#182968
01/03/09 10:19 PM
01/03/09 10:19 PM
NTOLERANCE
Madison Wi
Whats the diameter of the shaft that would go into the master? I will measure the master cup.
[Re: 1fastrunner]
#182972
01/08/09 03:34 PM
01/08/09 03:34 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Bought which one from where? Jim
I think he has the ebooger unit , go to the junkyard and get a pair of caps off an older dippy or pickup ...
[Re: 1fastrunner]
#182973
01/08/09 04:11 PM
01/08/09 04:11 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
IIRC all they are is a mid 80's M body or truck master cylinder...should be able to pick one up reasonably from the local parts store or rockauto.com
[Re: patrick]
#182974
01/08/09 04:32 PM
01/08/09 04:32 PM
RapidRobert
I have used drum ones on a disc conversion just by removing the residual valve(if it had one). You might try your current one since it is still good, just stick a drill bit deep into the brass seat on the side of the MC closest to the firewall & you'll feel the springy residual pressure valve if there's one in there & remove it if there is. The fluid capacity is less but we are on top of this as opposed to the general motoring public who do not check fluid levels as often as we do. Then you'll know & might save yourself some money & if you then want to change to an aluminum one it must have the recess for the manual brake pushrod & rubber retainer, just make sure you get the bore size thats right for YOUR combination THE FIRST TIME & the adapter plate & you're all set.
[Re: OLD318]
#182978
01/08/09 05:41 PM
01/08/09 05:41 PM
Posts: 1,069 Washington State
70Duster440
Washington State
Getting that type of pressure from a 1 1/32" bore master cylinder will require a VERY HEAVY FOOT... more than most people are used to or expect.
Do you mean 1 1/8"? They do require a heavy foot. I'm running one on my Duster and will be changing to a smaller bore. The common bore sizes found for replacement a-body master cylinders (Referencing NAPA) are:
15/16" - Power disc/drum 1 1/32" - Manual disc/drums 1 1/8" - (Common on trucks, including manual)
The interesting thing is, MP brakes says larger bore MC's are for power brakes, whereas Mopar seems to be opposite.
