Page 1 of 3 1 2 3
Richard Ehrenberg Master Cylinder #182959
01/03/09 08:53 PM
01/03/09 08:53 PM
Hunt Valley, Maryland
1fastrunner Offline OP
Does anyone remember the master cylinders that Richard Ehrenberg was selling here on Moparts? I just want to know if it will work for my application. I have a '71 RoadRunner with manual drum brakes. I'm putting spindles from a '76 A-body with 11.75 rotors and adapters from a R body. I'm not sure if my original master cylinder will work, if not, is this a good choice? My brakes will remain manual.
Thanks,
Re: Richard Ehrenberg Master Cylinder [Re: 1fastrunner] #182960
01/03/09 09:01 PM
01/03/09 09:01 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
A front drum brake master cylinder will not work with a disk brake conversion. That master cylinder should work as will several others. Provided its for a RWD disk brake equipped mopar car with manual brakes made from '73-on it should work well. The old standby could always be one for a '73-'74 Charger/Road Runner with manual brakes.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Richard Ehrenberg Master Cylinder [Re: 1fastrunner] #182961
01/03/09 09:05 PM
01/03/09 09:05 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Does your master have two bolts or four holding it to the firewall?
I have one of Eberg masters on my 65 Coronet and it originally had four bolts holding the master to the firewall, so I needed an adaptor.
Youll need a new proportioning valve when you go to disc brakes, as 4 wheel drums doesnt use one. Adjustable prop. valves are inexpensive.
Re: Richard Ehrenberg Master Cylinder [Re: NTOLERANCE] #182962
01/03/09 09:14 PM
01/03/09 09:14 PM
Mine has 4, I'm not sure what his had, but it did come with an adapter. I also have a proportioning valve to adjust the front and rear. So, if it's the same master. it will be good for my application?
Re: Richard Ehrenberg Master Cylinder [Re: 1fastrunner] #182963
01/03/09 09:36 PM
01/03/09 09:36 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I stock new, aluminum master cylinder packages with the correct 1 1/32" bore, billet aluminum adapter and push rod retainer.
E-mail me if you are interested.
Re: Richard Ehrenberg Master Cylinder [Re: 1fastrunner] #182964
01/03/09 09:52 PM
01/03/09 09:52 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Yepp, assuming its got the right bore size, which IIRC it does. Its a heck of alot lighter even with the adaptor. Youll need the adaptor.
Getting one from Dr. Diff would be a good option as well. I dont recall if Ebergs "kit" has everything. I had to use my old push rod and clip.
Re: Richard Ehrenberg Master Cylinder [Re: NTOLERANCE] #182965
01/03/09 09:59 PM
01/03/09 09:59 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, you can re-use your old MC push rod. I also make super-duty heim joint style adjustable push rods.
Re: Richard Ehrenberg Master Cylinder [Re: DoctorDiff] #182966
01/03/09 10:03 PM
01/03/09 10:03 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Any chance that could be modified to work with a hyd clutch?
Re: Richard Ehrenberg Master Cylinder [Re: NTOLERANCE] #182967
01/03/09 10:07 PM
01/03/09 10:07 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I don't see why not.
Re: Richard Ehrenberg Master Cylinder [Re: DoctorDiff] #182968
01/03/09 10:19 PM
01/03/09 10:19 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Whats the diameter of the shaft that would go into the master? I will measure the master cup.
Re: Richard Ehrenberg Master Cylinder [Re: NTOLERANCE] #182969
01/03/09 11:02 PM
01/03/09 11:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Off the top of my head, 7/16" diameter shaft machined down to about 3/8" on the ball end.
Thanks,
Cass
Re: Richard Ehrenberg Master Cylinder [Re: DoctorDiff] #182970
01/08/09 02:10 PM
01/08/09 02:10 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
I bought one...works but leaks around the caps. Ruined the paint on the inner fenders.
Re: Richard Ehrenberg Master Cylinder [Re: dwbiggs] #182971
01/08/09 02:29 PM
01/08/09 02:29 PM
Bought which one from where?
Re: Richard Ehrenberg Master Cylinder [Re: 1fastrunner] #182972
01/08/09 03:34 PM
01/08/09 03:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think he has the ebooger unit , go to the junkyard and get a pair of caps off an older dippy or pickup ...
Re: Richard Ehrenberg Master Cylinder [Re: 1fastrunner] #182973
01/08/09 04:11 PM
01/08/09 04:11 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
IIRC all they are is a mid 80's M body or truck master cylinder...should be able to pick one up reasonably from the local parts store or rockauto.com
2017 Grand Cherokee Overland
Re: Richard Ehrenberg Master Cylinder [Re: patrick] #182974
01/08/09 04:32 PM
01/08/09 04:32 PM
I have used drum ones on a disc conversion just by removing the residual valve(if it had one). You might try your current one since it is still good, just stick a drill bit deep into the brass seat on the side of the MC closest to the firewall & you'll feel the springy residual pressure valve if there's one in there & remove it if there is. The fluid capacity is less but we are on top of this as opposed to the general motoring public who do not check fluid levels as often as we do. Then you'll know & might save yourself some money & if you then want to change to an aluminum one it must have the recess for the manual brake pushrod & rubber retainer, just make sure you get the bore size thats right for YOUR combination THE FIRST TIME & the adapter plate & you're all set.
Re: Richard Ehrenberg Master Cylinder [Re: RapidRobert] #182975
01/08/09 04:51 PM
01/08/09 04:51 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
...or just get a new disk brake master at any auto parts store. They should still be aval new for a 72 car.
Re: Richard Ehrenberg Master Cylinder [Re: THESHAKERPROJECT] #182976
01/08/09 04:54 PM
01/08/09 04:54 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Most auto parts stores do not carry Mopar aluminum master cylinders. Most aftermarket 2 hole masters are cast iron.
Re: Richard Ehrenberg Master Cylinder [Re: THESHAKERPROJECT] #182977
01/08/09 05:06 PM
01/08/09 05:06 PM
O
OLD318 Offline
OLD318  Offline
O
If your doing the A-Body disc brake conversion I would not recommend a 1 and 1/32 inch bore master cylinder.
I would go with a 1 inch bore or a 15/16" bore
(Both bores are available in front disc/rear drum master cylinders from Bendix)
Why?
The smaller the bore, the higher the output pressure to the calipers. Your front disc brake calipers will require 1000 psi in order to function properly..
Getting that type of pressure from a 1 1/32" bore
master cylinder will require a VERY HEAVY FOOT...
more than most people are used to or expect.
What happends when the pressure is less than 1000 psi at the calipers?
Well, the brakes just won't seem to grab as well...
your expecting the car to slow down and stop and it won't, you'll have to press your foot harder
to get it to do what you want it to do...
meaning stop!
There is an excellent writeup of this subject on
Master Power Brakes website.. I think it is in the FAQ section on master cylinders...
Before grabbing spindles from 1 car and E'bergs master cylinder.. I would recommend you read up on this first...
Random parts thrown togethe
Re: Richard Ehrenberg Master Cylinder [Re: OLD318] #182978
01/08/09 05:41 PM
01/08/09 05:41 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Do you mean 1 1/8"? They do require a heavy foot. I'm running one on my Duster and will be changing to a smaller bore. The common bore sizes found for replacement a-body master cylinders (Referencing NAPA) are:
15/16" - Power disc/drum
1 1/32" - Manual disc/drums
1 1/8" - (Common on trucks, including manual)
The interesting thing is, MP brakes says larger bore MC's are for power brakes, whereas Mopar seems to be opposite.
Page 1 of 3 1 2 3
