Re: Cruise control on my road runner
[Re: MidPenMopar]
#1828807
05/17/15 10:16 PM
05/17/15 10:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Rostra is the only name that comes to mind for me. http://www.rostra.com/
[Re: mopars4ever]
#1829046
05/18/15 11:28 AM
05/18/15 11:28 AM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
I use to have a issue with that. I had too much spring on my carb. Yes, i am going to try to reduce the spring tension on the throttle if i can first but i think it's still not going to help that much.
[Re: Dabee]
#1830242
05/19/15 07:12 PM
05/19/15 07:12 PM
Supercuda
About to go away
About to go away
up yours
Trans type should make no diff. The cruse connects to the throtte linkage. Speed sensing is trans dependent with the kit his looking at.
[Re: Supercuda]
#1830261
05/19/15 07:47 PM
05/19/15 07:47 PM
MidPenMopar
Trans type should make no diff. The cruse connects to the throtte linkage. Speed sensing is trans dependent with the kit his looking at. That's actually a good thing in my case as i can hook it up to the GM overdirve i have.
[Re: MidPenMopar]
#1830278
05/19/15 08:09 PM
05/19/15 08:09 PM
Supercuda
About to go away
About to go away
up yours
Yes, point is though, it's trans type dependent.
[Re: Supercuda]
#1830397
05/19/15 11:01 PM
05/19/15 11:01 PM
Posts: 4,693 Wichita
GY3
Wichita
JC Whitney used to have one that worked off a sensor on the driveshaft...
[Re: Supercuda]
#1830442
05/19/15 11:46 PM
05/19/15 11:46 PM
Posts: 3,453 Dandridge TN
Dabee
Dandridge TN
Trans type should make no diff. The cruse connects to the throtte linkage. Speed sensing is trans dependent with the kit his looking at. All he needs to do is order the kit for his trans type. The only diff in the kit is the type of speed sensor used. I've installed several of these things using electronic speed signal from the ECU and cable driven signals using the kit supplied speed sensor. If installing on any vehicle that does not have an electronic Vehicle Speed Sender (VSS) or does not have a GM- type speedometer cable please order the CRS-3000-4165. The CRS-3000-4165 kit includes a magnetic drive shaft senders where magnets SEN-4165 are attached to the drive shaft to create a speed signal.
[Re: Dabee]
#1830496
05/20/15 12:30 AM
05/20/15 12:30 AM
Supercuda
About to go away
About to go away
up yours
Try replying to the post in question. What trans does he have?
[Re: MidPenMopar]
#1830658
05/20/15 10:55 AM
05/20/15 10:55 AM
Supercuda
About to go away
About to go away
up yours
Yes, I was following along. The E means electronic control, bet you have a VSS? Which pretty much tells you which kit to pick.
Never much cared for the magnets on the drive shaft setup, what happens when the zip tie fails, and it will.
